Paver Walk/Patio Install
/ Paver Walk/Patio Install #1
drm
Western PA, North of Pittsburgh
2004 NH TC33DA
I finally remembered to document a project I completed this summer with pictures so I can share. After purchasing our house I put in a man door to access the garage. The garage is on the side of the house around from the kitchen and front doors and is the main way we enter. Originally I put in some stepping stones but they were a pain to shovel and it tended to be muddy around them. So after two years it was time to put in a proper walk and area for the garbage cans.
I used UniLock brand pavers since I have had good success with then in the past and I like the available patterns. They must have two dozen different pavers available and a lot of colors. This is phase 1 of a multiyear project that will be fairly extensive connecting our driveway/garage to our pool (an earlier project this year) and to our back porch and walkout basement with a patio/fire pit between them. Due to the total area that will be covered I opted to use a rather large paver. I like the undulated surface and weathered (nicked and chipped corners and edges) look to this pattern. The field pavers are Stonehenge with a soldier course of Brussels Block around the outside.
I made the walk a little over 6' wide to allow room for the tractor and to tie into the existing mulch bed. Since my tractor, bucket and box blade are 5' wide I felt this would be plenty. Oops, took out the drain pipe the second day of digging. I began by marking out the area to dig and running the BB scarifiers over to break up the sod and soil (see Excavation photo).
I attempted to dig down to firm soil. At the drive that depth was 6” down. I hit some very rocky dry clay and it was hard digging. Wanted to go at least 8” so that I could get a solid base capable of supporting the tractor. Got to clear the snow off and what do you think I am going to use. Towards the other end I ran into very wet silty clay with large sandstone shale rocks up to 24” wide. I had to go down 12” to get to anything resembling firm.
Compacted the excavation and filled in any areas that were low with 2A modified (crushed 1 ½” minus gravel with the fines). Built this up in 2 ½” lifts compacting each lift with a Stone SFP 3000 20”x24” plate compactor. This puppy is 200# and applies a 3,000# force. The “Base” pic is about the third lift prior to compacting.
I used 8 tons of gravel to bring the area up to the sand level. I was very carefull on the final lift to get the correct height and slope. Each lift compacted approximately ¾”
I then screeded a 1 ¼” layer of concrete sand for the setting base using 1” PVC pipe as a guide. Used 1 ½ tons of sand I believe. Finally after 6 days it was time to begin laying the pavers. It only took one day to place the pavers but moving and laying 6,500# of concrete was tiring. The 12x12 blocks weigh 32#. Good thing I had my helpers (pics below). Helper 2 moved most of the small rectangular blocks (7# each) onto the pallet himself.
The picture of Helper 1 is after we covered the gravel pile and base with plastic. It rained or drizzled on me almost every day. After the pavers were all laid it was time to cut the pieces that needed cutting. Then installation of the plastic Snap Edge and another run of the compactor over the pavers to set them. After they are set brooming sand over the joints and a final run of the compactor. Then I backfilled around the pavers and mulched the area along the house. Now to plant seed in the grass I tore up in the wet/rain.
Of course the final picture was taken in the rain. Only fitting since I cursed the weather daily since I either got wet working or was inside looking out at the rain. The area that I paved is approximately 7’ x 22’ covering 150 sq ft.
My wife loves the final product. Now I get one more day of rest then it is on to the walkout basement area to start phase 2. That area is approx 15’ wide by 19 feet long (280 sq ft) and is between 2 brick faced retaining walls. That phase needs to be completed prior to knee surgery on the 22nd of the month. Wish me luck.
/ Paver Walk/Patio Install #3
Derek,
Nice looking job. I saw a crook in the line of pavers or so I thought until that camera lenses showed the opposite distortion from the other perspective. Should have known it had to be arrow straight ;) You sure are putting a very good base in with great compaction (tight lifts). Those pavers will be where you put them for many years. Most skimp on that and then wonder a few years (or less) later why things are moving. Solid ground, good base, and edge control is the only way to do it.
Glad to see those pavers broke you a sweat but sorry to hear on the knee. That's not exactly a bum knee kind of job, is it? Good luck on the weather and the knee.
bugstruck,
Yeah, a buddy who came to inspect it (he lays tile for a living) said the same thing until he walked around and sighted down the edge. I even had the string line still in place and he started to point it out. It does not help that I am using a camera phone so that adds some distortion. The area that looks like a crook in the edge is the high point and it drops off towards the near corner. I wanted to match grade in the foreground since it drops off to a 20 degree + slope where I am standing and did not want to increase it. The near corner will not be walked on much but I did not want to get into a curved edge and the associated cuts yet. That will begin in phase 3, next year? I was carefull with the path from the drive to the door. It is evenly sloped from the drive around the corner to the door. The slope to the grass from the door is also mild.
Your exactly right about the base. The guys I purchased the pavers from even said put 80% of your time into the base and it will turn out great & last.
I fininshed up Saturday, had 60+ over Sunday for a cookout and by Monday could hardly walk to cleanup. Needed a day or two to rest at a desk before starting again Thursday. I just hope this one goes better than the last. I still wear a brace on that knee when doing anything physical. I coach my kids spring tee-ball and summer baseball teams and get some good laughs at practices. Tried to ump without it and paid the price for 4 or 5 days. Never thought the years of sports and "ditch digging" would do me in so early.
/ Paver Walk/Patio Install #5
Nice job!!
What really caught my eye is all that grass you have. How long do you spend mowing!! hahaha
Eddie
/ Paver Walk/Patio Install #6
Excellent job! If ya ever get bored I could use some of your guidance(as in You do and I'll watch :D) on a future project of mine. Great job!
Will
EddieWalker said:
Nice job!!
Eddie
Thanks. It is a lot, spend three to five hours every 4 to 7 days depending on how long since the last cutting and how much it has grown. If I trim & edge add another hour or two.
I have not had a sizeable yard since '79 when we had 1 1/4 acres so I got a little carried away when we planted. Last yard was 1/4 acre, one before that was a 25' x 125' lot in Chicago. So I love my big yard. Just more seat time :D .
zenmek,
Thanks, I'll provide all the guidance you need from a lounge chair or you can wait until I'm done around here. I have projects lined up for the next 8-10 years. Maybe longer, every time I finish a house the wife decides it's time to move. I think I might need to slow down a little on this one.
