Pats Quick Hitch
/ Pats Quick Hitch #12
I have an MX5400 which is a Cat1/2 system...I'm looking to get a set of Pat's quick hitch adapters and I'm thinking I should order Cat 1....does it make a difference and has anyone put Pats on their MX5400? Any feedback on experience with them. All my equipment is Land Pride but one TMG tiller...thanks.
I know this is almost a year old thread . . . I have the exact same issue: I have a Kubota MX5400 with a hydraulic top link and side link. The tractor has a Cat 2 3pt and all my implements are Cat 1. I added a Pat's Quick Hitch (cat 2 for cat 1 implements). The top link was not long enough after the Pat's added 4" in length to the lower link hook up points. My solution was to extend the hook up location at the top link with a welded bracket (a friend is a machinist and did the work). Here's a picture. There is a thread somewhere here from someone who did the same thing but I can't find that thread now.
/ Pats Quick Hitch #13
Pats on my MX5200 work great. Did you know you can get cat 2 pins and put them on your cat 1 equipment?
That is the best option for an MX especially for a Pat’s quick hitch; get the Cat 2 hitch. It’s easy to change the pins or add bushings on a Cat 1 implement to use on a Cat 2 hitch. But if you only have a Cat 1 quick hitch then you can’t use Cat 2 implements on the MX. And that is limiting for a tractor that is designed to use both Cat 1 and 2 implements.
/ Pats Quick Hitch #14
Instead of a whole new PTO shaft, just get an extension ...
I don't use Pat's ... But to use a quick hitch ... On my L5030 ... Which has CAT 2 lower arms Input bushings in to get the CAT 1 quick hitch on, and the top of the tractor is CAT 1, but in order to get the length of the hydraulic top link I wanted, I had to get a CAT 2 cylinder, so I used bushings on both ends to bring it down to CAT 1 ...
2021 Dodge Charger Sedan (A59231)
2021 Dodge Charger...
Rooster Weathervane (A55853)
Rooster...
2024 JCB 35Z (A60462)
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Toro z turn (A56859)
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
