Quick Hitches Pat's quick hitch
/ Pat's quick hitch #1
robson1015
New Concord, Ohio
Kubota MX5100 and John Deere X 495
Will the Pat's system work on my MX5100 with telescoping link arms???? Thanx
/ Pat's quick hitch #2
I doubt that you would need the quick hitches with telescoping arms. That's what telescoping arms help you accomplish-an ability to hook up implements more readily.
H
/ Pat's quick hitch #3
This topic has just been discussed on the sponsored thread at the top of this forum. Read the last five or six posts.
The Pat's does not fit well on the telescoping arms. The release levers get in the way. You have some choices:
>Buy a full replacement for the telescoping arms. It is held in place by the existing release pin. The telescoping feature is lost. It is a special order item. The Pat's has the same geometry as the OEM balls so the PTO isn't affected. (I had these and sold them.)
>Buy the "weld-on" Pat's. Then cut the balls off the OEM telescoping arms and weld the Pat's in their place. The telescoping feature is still functional. The geometry is the same as OEM. (This is what I have.)
A welding shop would do the job for a reasonable fee.
Edit: Here is a photo of the "full replacement" Pat's for the extendable arms and made by Pat's.
The "weldable" Pat's is just the jaw portion. I cut off the balls in the lower photo and welded the jaws on. The result was a Pat's that looked like the top of the photo but has the adjustable attaching portion like in the lower half of the photo.
2013 Ford F-150 Pickup Truck (A61568)
2013 Ford F-150...
2025 80in. Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
UNUSED KUBOTA 18" EXCAVATOR BUCKET (A62130)
UNUSED KUBOTA 18"...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
