Pat's Quick Hitch system
/ Pat's Quick Hitch system #1
Madison, Ga
Kubota L3200HST with LA524 Loader, Quick Connect; Loaded R4 Tires
This looks like a great idea...I'm tired of wrestling with my 3-point attachments so I'm going to order a set today. My question is what does the $25 stabilizer bar do?
Any comments on this system would be appreciated.
/ Pat's Quick Hitch system #2
It is not really a stabilizer bar. It is used to spread the lift arms a specific amount so that the quick hitch ends line up perfectly with the implement pins. If you have implements that require different spacing, you can mark the bar so it can be set before use for the specific implement. Once the implement has been picked up, the bar is removed to prevent damage to it or the drive line. If you have horizontal stabilizers that are rigid and can be adjusted to the proper width, you may not need the bar.
/ Pat's Quick Hitch system #3
I've used the Pat's system for many years and like it. Be aware that for most installations, the system extends the length of the lower drag links by about 4". This may require driveshaft adjustments on some implements.
/ Pat's Quick Hitch system #4
PQH - GREAT
Stabilizer bar - I use a dowel and rubber bands.
And for the extra length a adapter will do.
/ Pat's Quick Hitch system #5
I have Pats and they work great. Bought the stabilizer bar too. The bar would hit 1 of my implements at a certain height and bend. Since then I added rigid stabilizers replacing the turnbuckles and now I no longer use the stabilizer bar.
/ Pat's Quick Hitch system #6
/ Pat's Quick Hitch system #7
In addition to the driveshafts, you will most likely need a longer top link. That's not a big deal, but something you will need to remember.
When I installed my Pat's system all of the driveshafts worked out OK, but I did have to buy a new top link from TSC.
/ Pat's Quick Hitch system #8
I didn't get the cross bar and don't need it as my arms stay spread. I didn't need longer top link or pto shafts either. Guess I got lucky.
I have been real happy with the quick hitch. So much easier to change implements.
Thanks gang...ordering it now on the Black Friday special. I'll let you know what I think about it after using it a while.
Sellick S80 (A60462)
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
Bobcat T650 Compact Track Loader (A64047)
Bobcat T650...
2017 CATERPILLLAR 938M WHEEL LOADER (A62129)
2017 CATERPILLLAR...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
