Pat's Easy Change Pats easy change system?
/ Pats easy change system? #1
_RaT_
Super Member
Peoples Republic of Northern CA.
Kioti 3510-SE HST
What are your thoughts about Pats easy change system? I have passed the link on to some folks that really like the idea. At less then $200, they thought the price a small factor if the product works. Common sense seems to evoke an idea of pure simplicity, what about actual use? It sure would make sense for me if my L3830 HST wasn't already so simple. Thanks in advance. Mark
/ Pats easy change system? #2
i installed the pat's system last week,i have only used it once and it is so much easier to hook up it is well worth the price!!
/ Pats easy change system? #4
I've had mine since fall and think it works fine. I no longer have to wrestle implements back and forth to get the link pins lined up.
/ Pats easy change system? #5
I installed my Pat's in late summer on a TC24D and love it. I bought the optional cross brace/stabilizer bar, but I have not had to use it. I've seen some other posts on TBN where people swear by the optional bar. Basically Pat's Easy Change is as simple as it looks and it works. The instruction sheet that comes with Pat's leaves a lot to the imagination, but if I can figure it out, I think any one should be able to.
/ Pats easy change system? #6
I put Pat's system on my little Kubota and I really like it. I really like the ease of use and simplicity of it.
/ Pats easy change system? #7
Just got mine mounted on my M4900 this past week-end (see my other post this section). Other than the pin problem, I think the product is well made and should work great. Anything has got to be an improvement over trying to align everthing by yourself. Have not hooked up anything yet. My stabilizer bars should keep everything in alignment.
/ Pats easy change system? #8
FYI,i just saw the pats system being sold through Northern Tool and Hyd.,the price on the cat 2 was the same as pats but the cat1 was $20 higher(both were $199
2019 KENWORTH T680 (A67714)
2019 KENWORTH T680...
2003 FORD F-750 SUPER DUTY(INOPERABLE) (A67714)
2003 FORD F-750...
2005 MACK CHN613 (A67714)
2005 MACK CHN613...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2014 FORD F-150 (A67714)
2014 FORD F-150...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
