Pat's Easy Change Pats easy change system..
/ Pats easy change system.. #1
Chuck K.
Texas Gulf Coast
2009 M59 w/thumb
I can not say enough good things about them. Took of the mower in about 30 seconds, cant see any reason why it would take more the a couple minutes max to hook it back up after getting the hang of it.
The spreader bar device is well worth the money just dont make a BONE HEAD move like me and forget to install the cotter pins, one end falls out and chop it up with the mower :( It can be fixed just another saftey reminder to check your equipment well even if you are in a hurry to get a seemingly simple job done...
/ Pats easy change system.. #2
I'll make my own bonehead moves, thank you very much! Like trapping the PTO shaft under the spreader bar. :eek: Luckily the spreader comes off easily enough after the hooks are engaged so no harm done, and I can echo that the spreader bar is definitely worth the investment.
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
2009 PROCO 130BBL (A65643)
2009 PROCO 130BBL...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
