Pat's Easy Change Pats easy change system..
/ Pats easy change system.. #1
Chuck K.
Texas Gulf Coast
2009 M59 w/thumb
I can not say enough good things about them. Took of the mower in about 30 seconds, cant see any reason why it would take more the a couple minutes max to hook it back up after getting the hang of it.
The spreader bar device is well worth the money just dont make a BONE HEAD move like me and forget to install the cotter pins, one end falls out and chop it up with the mower :( It can be fixed just another saftey reminder to check your equipment well even if you are in a hurry to get a seemingly simple job done...
/ Pats easy change system.. #2
I'll make my own bonehead moves, thank you very much! Like trapping the PTO shaft under the spreader bar. :eek: Luckily the spreader comes off easily enough after the hooks are engaged so no harm done, and I can echo that the spreader bar is definitely worth the investment.
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A64557)
2014 Crossroads RV...
2022 KUBOTA KX057-5 EXCAVATOR (A65053)
2022 KUBOTA...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
John Deere 4840 Tractor (A66285)
John Deere 4840...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
New/Unused 110V Diesel Pump with 50ft Hose (A65583)
New/Unused 110V...
