Pat's Easy Change Pat's Easy Change System Question
/ Pat's Easy Change System Question #1
bambam
Pat\'s Easy Change System Question
I have been reading with interest about the Pat's Easy Change System in this forum. Looks very spiffy (beats moving 500 lbs of box blade to get the pins in those little holes...).
In the specs it says that the lift arm needs approximately 4" of straight arm. My Kubota L3000DT arms have about 3 1/2" of straight arm. Does anyone have experience with the Pat's system and the L3000DT, and, if so, does it fit or no?
Thanks;
Bambam
/ Pat's Easy Change System Question #2
Re: Pat\'s Easy Change System Question
Might be better to go directly to the guy who makes them at PatrickG@bbtel.com with this question.
Just as a follow-up, I took the suggestion and contacted the manufacturer. Pat responded promply and says that the Easy Change system will fit the L3000DT.
Just in case anyone else was wondering....
Thanks;
bambam
/ Pat's Easy Change System Question #4
</font><font color="blue" class="small">( Just in case anyone else was wondering.... )</font>
Now that's good TBNing. Thanks, John
/ Pat's Easy Change System Question #5
Anyone with a Pat's quick change on a BX2200? Just wondering if it works for the rear bagger, since the adjustable arm is not used in that application. Thanks
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
2000 Generac SG068 75kVA Natural Gas Generator (A66734)
2000 Generac SG068...
2004 CHEVROLET MALIBU 4 DOOR CAR (A66091)
2004 CHEVROLET...
CENTRAL PNEUMATUC 9 GALLON GAS AIR COMPRESSOR (A67714)
CENTRAL PNEUMATUC...
2009 IHI IC70-2 CRAWLER CARRIER (A65056)
2009 IHI IC70-2...
2016 Ford Expedition SUV (A66738)
2016 Ford...
