Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #381
I must say this is one of the best things I ever bought for my kubota l4200!
I bought the weld on ones because I didn't want the extra 2 1/2" of lenth and everyone leaves them on anyway,so I cut my arms and welded them up I could not be any happier .This makes hooking up attatchments kind of fun instead of a chore.Any one trying to decide if they want them,buy them you won't regret it!!!!!!!:D:thumbsup:
   / Pat's Easy Change System - Order Online! #382
Anyone using these on a Kubota B2710? Just wondering if I'll need to find a new top link. The longer ones are not that easy to find.
   / Pat's Easy Change System - Order Online! #383
I am new to tractors so I apologize in advance if these questions are elementary.
I have a New Holland Workmaster 55. It has a Cat 2 but works with Cat 1. Two of my implements are Cat 2 and one is Cat 1. If I buy the Cat two Easy Change will it also work with the Cat 1 implement and will it work with my LP Brush cutter?
   / Pat's Easy Change System - Order Online! #384
Yes. I have about the same deal with a CAT 2 on an old 265 MF. I ordered the CAT 2 version PECS. On the Cat 1 stuff I just put on a 1 to 2 bushing and put in the pin and leave it.
   / Pat's Easy Change System - Order Online! #385
I got my PEC last week and installed it over the weekend on the CAT 1 3PT on my CCY SX3100. The installation process is a bit more lengthy than the videos let on ;) So far, I've only tried the PEC with two implements - a Woods PRD7200 finish mower and a TSC carry-all. Here are my experiences with those two items:
The finish mower has pins on rotating links, so unhitched and at rest the pins are below the lowest level to which the 3PT lift arms can be depressed. Thus, the advantages of the PEC are nullified since I have to get off the tractor and manually shift the mower into place with each link held up so the pins sit on top of the hooks. Then I have to go back around to operate the lift arms, hoping the pins are positioned well enough that they drop down into the hooks on the PEC. In fact, it's easier to hook up the finish mower to the un-PEC'ed lift arms. If I can figure out a way that the links could be held up by some kind of spring-loaded catch that's released when the PEC is backed into place, then the PEC will be worthwhile for use with my finish mower.
The 100-lb carry-all initially was unloaded, so it was hard to get the latches on the PEC to depress enough that the pins on the carry-all could drop down into the hooks, without the unhooked carry-all being lifted and shoved backward. This was on a concrete floor by the way, so perhaps setting the unladen carry-all on dirt or grass would help keep it fixed in place while backing up the tractor. With a load on the carry-all, the PEC worked fine, even on a concrete floor.
I'm guessing the PEC was designed solely for heavy implements with fixed links, so my experiences probably are atypical. I will, however, be using a rear blade and possibly a box blade in the future, so I'm sure the PEC will shine through at that time. But for now, with the finish mower being used the most, I'll probably leave the PEC off my tractor.
   / Pat's Easy Change System - Order Online! #386
I understand the concern, I hate not being sure about a site. I've talked to the people at Pat's and they are real nice. I like to call companies I order from even when I order online for the first time just to make sure they "sound legit".
Now off to work. Today is Cultivate, mow and bush-hog day!:D
   / Pat's Easy Change System - Order Online! #387
Does anybody use the PEC system with stabilzer bars. I have them on my Ford 640 to keep the implement (particularly the bush hog) from swaying from side to side.
   / Pat's Easy Change System - Order Online! #388
I see on the PEC website that they have a new style one piece latch. Does anyone know if the ones being sold by TBN are the new style or older style? Any thoughts on if really makes that big a difference which ones I get?
Thanks.
Paul
   / Pat's Easy Change System - Order Online! #389
All cat#1 and cat#2 are going out with the new latch.
   / Pat's Easy Change System - Order Online! #390
Was the install of the weld on units fairly straight forward? I'd rather not have the added length also since I've cut my PTO shafts to length. Did the weld ons add any length?
Thanks
Jeff
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Heavy Duty Excavator Ripper (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty...
LOT: (17 approx. ) Rolls of Chain Link Fence (LENGTH UNKNOWN) (A59076)
LOT: (17 approx. )...
