Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #141
Pat,
My back thanks you, my knuckles thank you, and my neighbor's ears thank you.
Good stuff and well made.
Big Dad
   / Pat's Easy Change System - Order Online! #142
My Pat's Easy Change System showed up in less than 3 days and has been installed on my tractor for about 2 weeks now. All I can say is why did I wait so long. I wish I had these years ago. I mean I can hook up to my bush hog in about a minute and when done disconnect in less than a minute and hook to my blade in another minute. The PTO takes longer to hookup than attachment. Time savings is good but the lack of frustration of getting on and off the tractor to line up pins and holes, kicking and prying to get the lift bars on and off are just a few I don't need to do any more and is a major benefit to my feet, hands, sanity. I thought they were a little pricey, but now I'm so glad I bought them. Worth every red cent.
Tractors should come standard with them!
Peter
   / Pat's Easy Change System - Order Online! #143
These folks are relentless.
Pat will not, under any circumstances, allow me to be an unhappy customer. They again have sent me an extension piece for my machine. The first one was a tick wide on a fit. He sent me a second one, no questions ask (other than dimensions), no request for their time and effort, nothing. Nothing but satisfaction.
Thank you Pat...
   / Pat's Easy Change System - Order Online! #144
Greenwell Mfg. has awesome customer service! They've fixed me up more than once now, above and beyond expectations.
   / Pat's Easy Change System - Order Online! #145
Is anyone using Pats QH with a KK tiller (48")? I'm looking to mount the KK on a GC2310, but it doesn't open to 33"!
   / Pat's Easy Change System - Order Online! #147
I still don't really know what the bent washers are for? Do they go on the implements? Can anyone post a pic of one in use. Sorry, I did read the thread, but still don't get it.:confused:
   / Pat's Easy Change System - Order Online! #148
They help keep the arms on the implement, you can (barely) see them in use here, if you need me to I can snap a better picture tomorrow.
   / Pat's Easy Change System - Order Online! #149
Oh, so they keep the Pat's arm from sliding off of the implement. So that's why there are 8, for your different implements. I think I got it now. :eek:
Thanks. Been smoking any large animals pieces on that cooker?
   / Pat's Easy Change System - Order Online! #150
Just installed my Pat's Easy Hitch System yesterday on my Kubota B7800. Lined up the hook on the lift arm using the shim, set screws, and tightened down U bolt. Backed up to my KK boxblade and the hooks looked to line up nice and square to the lift pins. But, when I lift the boxblade the top of the hooks tend to pull inward, which puts all contact on the inner side surface of the hook. I guess this all comes about because the balls on the end of the lift arms are unable to rotate as they normally would. Anyone know of a way to correct this problem or is it okay to just use it like that? All input will be appreciated and thanks.
___________________
Backhoe,FEL,Subsoiler,Backblade,Boxblade,6' Woods finish mower.
Husqvarna 46in Riding Mower (A56859)
Husqvarna 46in...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
kohler generator (A56857)
kohler generator...
