Pat's Easy Change System and Canada
   / Pat's Easy Change System and Canada #11
   / Pat's Easy Change System and Canada #12
I took a close look at these and passed. I could not see them lasting as I back into my 1300 lb concrete counterweight and then carrying it around.
If you're looking for something that can take some abuse and will most likely outlast the tractor, check the Euro style lower links.
These just work right. Sure, takes a bit more work for the first time as it requires cutting the old ends of the arms and weld the hooks on, but it doesn't extend the arms any further, retains the ball joint and it's very easy to connect. The PATS just restrains all of these movements and then you see people complaining about broken bolts. As far as price, I've seen the kit for $300 or individual parts for a lot less.
Don't know about shipping to Canada but AgristoreUSA sells those and so does @MtnViewRanch from Fit Rite Hydraulics. He is a member here.
   / Pat's Easy Change System and Canada #13
Sad but I do believe that is correct a lot of the times, we're so complacent and used to getting ripped off we've come to accept it as normal........Mike
Well I don't accept it as normal. I order roughly 80% of my car parts from the States. They are usually at my local post office in 4 days from anywhere in the US if I let FedEx do the shipping. If I place my order in the early morning in 2 days the parcel is in Memphis. The next day to Calgary and through customs. Then the parcel gets a Canada Post label and I pick it up at my local Post Office before or at noon the next day.
1991 International 4900 Box Truck (A55315)
1991 International...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2018 CATERPILLAR 259D SKID STEER (A52707)
2018 CATERPILLAR...
20704 (A55853)
20704 (A55853)
2023 JOHN DEERE 325G SKID STEER (A52707)
2023 JOHN DEERE...
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
