Pat's Easy Change on a GC17xx . with backhoe?
   / Pat's Easy Change on a GC17xx . with backhoe? #1
gojira
Central NH
JD X590, MF GC1710
Has anyone installed a Pat's quick change on the 3 point system for a GC17xx with a backhoe? If so, does it fit under the frame when you fold it up to reinstall the backhoe?
Mounting my chipper/shredder is a pain in the butt and I'm thinking this would make my life a lot easier. Thanks!
   / Pat's Easy Change on a GC17xx . with backhoe? #2
Took a close look last night at my arms. I think the ends will fit, just a little nervous on where they would hit my legs when I am running the hoe. Sitting in the seat I think you would notice them. Whether that bothers you or not I can稚 say.
Thanks!
I'm picking up a cheap cat 1 quick hitch I found locally later today, so I'll give that a try first. If that doesn't work out I'll try the Pat's solution.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
