Pat's Easy Change on a GC17xx . with backhoe?
   / Pat's Easy Change on a GC17xx . with backhoe? #1
gojira
Central NH
JD X590, MF GC1710
Has anyone installed a Pat's quick change on the 3 point system for a GC17xx with a backhoe? If so, does it fit under the frame when you fold it up to reinstall the backhoe?
Mounting my chipper/shredder is a pain in the butt and I'm thinking this would make my life a lot easier. Thanks!
   / Pat's Easy Change on a GC17xx . with backhoe? #2
Took a close look last night at my arms. I think the ends will fit, just a little nervous on where they would hit my legs when I am running the hoe. Sitting in the seat I think you would notice them. Whether that bothers you or not I can稚 say.
Thanks!
I'm picking up a cheap cat 1 quick hitch I found locally later today, so I'll give that a try first. If that doesn't work out I'll try the Pat's solution.
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2018 INTERNATIONAL BOX TRUCK (A52472)
2018 INTERNATIONAL...
