Pat's Easy Change for BX23. Does it work?
/ Pat's Easy Change for BX23. Does it work? #1
vlpena
Colorado County, Texas
Kubota BX23
Pat\'s Easy Change for BX23. Does it work?
Been looking at the Pat's Easy Change for adding to my BX23. Looking for feedback (pro and con).
The only attachment is a 42" mower that it would be used on. Also, when the BH is re-attached, would these get in the way when you have to retract the arms?
/ Pat's Easy Change for BX23. Does it work? #2
Re: Pat\'s Easy Change for BX23. Does it work?
The Easy Change thingies attache to the ends of the 3pt arms...which are not on the machine when you install the BH, unless they've changed something between the BX22 and the BX23. The whole 3pt is dismounted before the 'hoe is attached. Therefore, "Pat's" system would not interfer with the backhoe.
/ Pat's Easy Change for BX23. Does it work? #3
I've heard nothing but good stuff about Pat's easy change system, and have been thinking of getting it myself. But I have a box blade which is not open on either side of the pin you hook onto. In other words my hook up looks like this:
|-| instead of the normal --| and |--
I wonder how wide the quick attach mechinism is and would it work on a hook up like my box blade? My brother borrowed my digital camera, once I get it back I'll snap a pic to better explain, if needed.
Thanks,
Moon of Ohio
/ Pat's Easy Change for BX23. Does it work? #4
Moon, my tiller is set up the way your box blade is configured. Pat's system works fine with the tiller. You simply eliminate the use of the washer thingy on that type of implement connection.
/ Pat's Easy Change for BX23. Does it work? #5
Thanks Bob!!!!
I was hoping it would work for that kind of hook up.
Moon of Ohio
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
2022 EZ-GO ELITE...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
Kubota Snow plow with subframe
Kubota Snow plow...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
case 370 glass door never installed (A61307)
case 370 glass...
