Pasture Fence...Setting Wood Posts
   / Pasture Fence...Setting Wood Posts #1
swiederin
Breda, IA
Oliver
I am getting ready to build new fence and would like to know if anyone uses crushed rock to set wood corner and brace posts in.
Yes/No? Use another type rock? With fines? What size?
Thanks.
   / Pasture Fence...Setting Wood Posts #2
Naw, my Kentucky ground is rocky enough. I have always used whatever dirt came out of the hole. Tamp it tight and come back after the ground settles and tamp again. Line post are 18"-24" deep, corners are are 36" or more if I can. Posts 12' to 15' apart. But it's your fence, build it to you.
   / Pasture Fence...Setting Wood Posts #3
I just always use the dirt from the hole. I tamp it hard and if I don't run out of dirt I know I did not do a good job. I run out of dirt about 3 or 4 in from the top of the hole.
   / Pasture Fence...Setting Wood Posts #4
Always used treated fence posts and just used hole material.
   / Pasture Fence...Setting Wood Posts #5
I'ved used hole material and stone from our gravel road. Both last the same. What still needs to be addressed is why you dig a hole, install a post that's 50 to 75% of the hole diameter, and you are almost shy of filler....
Be sure to tamp in the dirt (or gravel) as soon as the post is set in and a few shovels of filler are there. Don't wait for all the hole to be filled and tamp then. Otherwise the post can tilt.
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2002 TOYOTA 7FDKU40 FORKLIFT (A54607)
2002 TOYOTA...
2000 GROVE RT640E MOBILE CRANE (A51406)
2000 GROVE RT640E...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
