Parts washer
   / Parts washer #1
Bsavulis
Putnam, Connecticut
Kioti CK25
Just picked up a HF parts washer. The 20gal tub with a pump. What do you guys use in your washers? I was going to get K1 kerosene, or just diesel. Any thoughts?
Brian
   / Parts washer #2
Brian
I believe those pumps are only for water based cleaners
   / Parts washer #3
Yes, do check the specs for your pump. It may not handle hydrocarbon solvents. What you use will depend on what you're cleaning and whether it will be painted afterward. K1 and diesel are way too "oily" for my liking. You'll have to wash the parts after cleaning if you intend to paint them. :rolleyes:
I used to use Graymills Regular Agitene solvent, but it got so pricy I started mixing my own. I use a mix of 90/10 naphtha and paint thinner (mineral spirits). The paint thinner raises the flash temperature without making it too oily or leaving a residue. Even that's getting expensive these days. I've been using that in an old Graymills drum mount cleaner for years.
   / Parts washer #6
Let your pocketbook decide.
  • 11% OFF
    B'laster Parts Washer Solvent. 11% OFF.
    $114.04$128
    favicon-tbn
    Amazon.com - Seller & more
    Free delivery
    4.5(31)
  • 20% OFF
    Crc Parts Washer Solvent 05067. 20% OFF.
    $123.99$155
    favicon-tbn
    Advance Auto Parts & more
    Get it by May 2 (Free)
    4.1(20)
  • Summit Racing Parts Washer Degreaser SUM-941245-1.
    $12.99
    favicon-tbn
    Summit Racing
  • Zep Professional Parts Washer Solvent.
    $149.99
    favicon-tbn
    Free delivery
  • LOW PRICE
    Bio-Circle Parts Washer Cleaning Solution 55A107. Low price.
    $207.78Usually $296
    favicon-tbn
    coxtool.com & more
    Free delivery on $500+
  • Graymills Parts CLEANERS/WASHERS-SOLVENT.
    $142.95
    favicon-tbn
    Grainger Industrial Supply & more
   / Parts washer #7
I'm running Stoddard in mine. Many years ago there was a Shell distributor up in Woodburn that had it on a pump for like $1.53 a gallon. Took two 15 gallon plastic drums up. Wish that still existed.
   / Parts washer #8
Diesel leaves an oily film behind, I don't want that on some parts that I wash.
I have mineral spirits in mine.
SR
John Deere Disc (A49251)
John Deere Disc...
Farmall A 2WD Tractor (A49251)
Farmall A 2WD...
72in Large Capacity Bucket (A49251)
72in Large...
1998 Express Trailer 14ft T/A Concession Trailer (A46683)
1998 Express...
2023 FREIGHTLINER CASCADIA PT126SLP TANDEM AXLE SLEEPER (A45678)
2023 FREIGHTLINER...
Equipment Questions (A47164)
Equipment...
