Parts for John Deere 4020
   / Parts for John Deere 4020 #1
fharshaw
Lampasas TX
4020 John Deere
Does anyone know where to get a pivot valve for the hydraulic system that will fit on a John Deere 4020 tractor? I've been told that you can't get them from JD
   / Parts for John Deere 4020 #2
I would check on Deereparts.com and see for your self. Then I would Google the part number to see it anything comes up.
   / Parts for John Deere 4020 #4
With 21 + years experience working at a JD dealership I must ask what are you referring to as a "pivot valve"? What part # are you looking for?
I wasn't there when the repair person came so this is second hand info. He reportedly said that the "pivot valve for the hydrolytic system was worn & needed replacing & JD didn't support it anymore". I haven't looked in my manual yet & thought I might get a quick answer. Guess I'll have to do my homework & call him; then find in my manual. It sounded a bit funny to me but I haven't done much work on the hydrolytic system. Thanks for the reply
   / Parts for John Deere 4020 #7
Some parts are a little tricky to locate on JDparts.com. If you experience any difficulty locating the part someone on this site will be happy to assist you. I wonder if your mechanic meant pressure control or stroke control valve. Most 4020 parts are readily available because so many 4020's were built and are so popular.
   / Parts for John Deere 4020 #9
Could I ask what symptom you are having that requires this valve? That might point us in the right direction.
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
EZ GO EXPRSS S4 EFI GAS GOLF CART (A51247)
EZ GO EXPRSS S4...
