parts availability
/ parts availability #1
dbltrbl
mitsubishi satoh s470
Hi fellas. New member here. I have a Mitsubishi Satoh S470. What is a good source for common parts sucha s filters etc.?
Thanks for the info guys.
/ parts availability #6
I forgot to tell you the oil filter # is 1334 at NAPA
I was able to get all the filters I needed. The only part I need now is a tach cable. Also, has anyone found matching paint colors?
/ parts availability #8
There's a Ford engine enamel in a spray can that is a dead ringer for the Satoh blue. I've used it, and you can't tell the difference in color. Plus, it's good paint, high temp and everything. I still have the can if you need the #. I think I got it at Tractor Supply.
/ parts availability #9
For the off white paint I use the white paint for International Harvester. This is also available at Tractor Supply.
Thanks. I'll pick some up.
/ parts availability #11
Mitsu blue is a dead match to Tremclad medium blue.
I'd suspect Sotah blue is the same.
For the white I used Tremclad white that I tinted 'til I got a match.
/ parts availability #12
That's the same filter as the S370...And my Subaru Impreza. :D
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
E-Z TRAIL 500 GRAIN CART (A64277)
E-Z TRAIL 500...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
Lifts (A61567)
Lifts (A61567)
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
