parts availability
/ parts availability #1
dbltrbl
mitsubishi satoh s470
Hi fellas. New member here. I have a Mitsubishi Satoh S470. What is a good source for common parts sucha s filters etc.?
Thanks for the info guys.
/ parts availability #6
I forgot to tell you the oil filter # is 1334 at NAPA
I was able to get all the filters I needed. The only part I need now is a tach cable. Also, has anyone found matching paint colors?
/ parts availability #8
There's a Ford engine enamel in a spray can that is a dead ringer for the Satoh blue. I've used it, and you can't tell the difference in color. Plus, it's good paint, high temp and everything. I still have the can if you need the #. I think I got it at Tractor Supply.
/ parts availability #9
For the off white paint I use the white paint for International Harvester. This is also available at Tractor Supply.
Thanks. I'll pick some up.
/ parts availability #11
Mitsu blue is a dead match to Tremclad medium blue.
I'd suspect Sotah blue is the same.
For the white I used Tremclad white that I tinted 'til I got a match.
/ parts availability #12
That's the same filter as the S370...And my Subaru Impreza. :D
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
213130 (A64276)
213130 (A64276)
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2022 EZ-GO ELITE...
John Deere S350 (A60462)
John Deere S350...
