partimefarmer
/ partimefarmer #1
partimefarmer
Galva,Kansas
9282 new holland
I own a 9282 New Holland 4-wheel drive tractor my M P H display on the dash is reading to slow, for example on the road it will show 12.8 I put a portable G P S in the cab and it shoes 16 which is correct, I have installed a new speed sensor,I have recalibrated it to the top end wich is 50 the range of calibration is 20 to 50 I just bought the tractor it was set on 46 at first then it was showing 11.8 so you see it helped a little not enough, I have contacted 3 diffrent service managers in the area, they all tell me they will have to do some research and get back with me nothing happens. one of them told me to check the ohms on the speed sensor it should read somewhere in the 1000 to 1200 range I did that and I have 1240 ohms, so where do I go from here. Any ideas would be appreciated, THANK YOU IN ADVANCE
/ partimefarmer #2
Tire size will affect the speed are the tires the originals ?
/ partimefarmer
tires are not original but are original size and also I have calibrated it to the top end so I should be able to calibrate it to the tire size any way. Am I right?
Bestway 750 Sprayer (A66285)
Bestway 750...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2016 CHEVROLET SILVERADO 3500HD DUALLY (A65643)
2016 CHEVROLET...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
