Part source needed
/ Part source needed #1
RFB
Platinum Member
None
Sirs,
I am looking for the plastic protective caps for hydraulic hose fittings. I have googled multiple search terms and come up zero, which is frustrating since I know they exist. Also, are they available for the male end as well as the female end?
I am also looking for nylon protective hose sleeves (if that is what it is called) that allow installation without hose removal.
Thanks in advance for any help,
RFB
/ Part source needed #2
If they were for my tractor I would try contacting my local tractor dealer. I doubt if an auto parts store, like NAPA, would have the covers, they don't tend to have those size couplers, in my experience. Seems like even if the tractor dealer didn't have them, they could tell you who did.
/ Part source needed #3
For corrugated nylon split tube look in electrical section of a large hardware store. It is used to cover wire bundles.
/ Part source needed #4
<font color="blue"> I have googled multiple search terms and come up zero, which is frustrating since I know they exist. </font>
The common name is dust caps & plugs.
They can be found under Quick Couplers. Here is a link to one supplier. Click Here
<font color="blue"> I am also looking for nylon protective hose sleeves (if that is what it is called) that allow installation without hose removal.
</font>
In another thread. It was suggested that using old firehose would be a good way to protect hoses. Slice it to fit. Then tie rap it on.
/ Part source needed #5
Look here for the sleeves. They probably have the caps too. Several of us here on TBN have used these people and are quite satisfied.
Discount Hydraulic Hose
/ Part source needed #6
My local Napa would have them stocked on the shelf - depends if you are in an ag location or not I guess.
Any farm supply store - TSC, Runnings, C&N, Fleet & Farm, and on & on - will have them on the shelf as well.
Any color tractor dealer will have them as well - probably at more money.
Valu-Bilt, Surplus Center, Northern Hydraulics, and all the rest of the catalog/web stores should have them as well.
Everything you mention is available, yes.
--->Paul
832785 (A61166)
832785 (A61166)
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2022 Case TR310B Compact Track Loader (A61166)
2022 Case TR310B...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2004 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2004 V.E...
flatbed trailer 24ft (A56857)
flatbed trailer...
