Part name that acts as stop?
   / Part name that acts as stop? #11
I have used fender washers without bending them over, works just as well. The only issue in doing that is if you unhook and hook up often to the same piece of equipment the washers may walk and not be out on the ends of the pins, but in operating times the washers work fine.
Buying fender washers and bending them over can be done, but you will have to cut a notch in the bent over flange for the lynch pin to go through.
   / Part name that acts as stop? #12
They are cute bent washers, but I'm not sure I see any advantage mechanically. Wouldn't it work better to just stack up some washers or cut a piece of pipe to length?
MASTER FLOOR HEATER (A53843)
MASTER FLOOR...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2014 LAMAR TRAILER (A53843)
2014 LAMAR TRAILER...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
