Part name that acts as stop?
   / Part name that acts as stop? #11
I have used fender washers without bending them over, works just as well. The only issue in doing that is if you unhook and hook up often to the same piece of equipment the washers may walk and not be out on the ends of the pins, but in operating times the washers work fine.
Buying fender washers and bending them over can be done, but you will have to cut a notch in the bent over flange for the lynch pin to go through.
   / Part name that acts as stop? #12
They are cute bent washers, but I'm not sure I see any advantage mechanically. Wouldn't it work better to just stack up some washers or cut a piece of pipe to length?
2017 Challenger 607P-FS Vacuum Pump (A53117)
2017 Challenger...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
