Parking Brake Question?
/ Parking Brake Question? #1
Steelfan
Platinum Member
Central PA
New Holland TC21D
I have a quick question about the parking brake on the TC21D. I've been getting myself used to putting the Parking Brake on when I get off my Tractor. I do have a couple of small problems with the operation of the brake. Does anyone find it hard to release the brake at times? It seems like somthing is in the way for the brake releasing properly. I will say that the problem surfaced when I took the MMM off the tractor. When you take the mower off do you have to also take the swinging arms off. I left mine on. I disconnected at the mower. Thanks to anyone who can help. Kent
/ Parking Brake Question? #2
Steelfan,
Also had a problem on my TC40D with the parking brake not wanting to release. Does it feel stiff? Mine was stiff and would release if I pushed the handle down while pressing the brake down. It was easily fixed by greasing a couple joints that I had overlooked during previous lube jobs. Of course all this is worthless if the TC21D has a different parking brake mechanism from the TC40D...
Hi DVerbarg,
On the TC21d you push down the brakes, and pull up on a lever under the seat. At that point it locks in place. The lever under the seat doesn't help with releasing the brake. You must push the brake a second time to release the brake. Thanks for the post. There is grease fitting there. May be part of the problem. Kent
/ Parking Brake Question? #4
Steelfan,
By your description your parking brake works the same as mine. When you press the brake down the handle under the seat drops by itself (normally), right? If it doesn't drop, as it did in my case, I was able to push the handle down while pressing the brake. Hopefully your issue is just a simple grease job to resolve.
Thanks Dave, I'll try greasing it. Kent
/ Parking Brake Question? #6
Dave, ditto on your advice. I've greased mine twice and it works fine. That's one of those little owner tips they don't have in the book (I think).
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2017 Ford F-250 Pickup Truck (A61573)
2017 Ford F-250...
WHITE 2-60 TRACTOR (A63291)
WHITE 2-60 TRACTOR...
12in. Tooth Excavator Bucket (A64194)
12in. Tooth...
2017 Volkswagon CC Sport Sedan (A61574)
2017 Volkswagon CC...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
