Parking Brake Problems
   / Parking Brake Problems #1
wvrocks
Tucker Co, WV
TC-33 DA
I've been having some problems with my parking brake recently. When I want to get off the tractor and leave it running it almost always stalls out even though its in neutral and the parking brake light is on. What I usually do is put the tractor in neutral and move the treadle back and forth to make sure is really in neutral. Then I set the parking brake firmly and the light comes on. Stand up from the seat and in a few seconds it dies out. If I just lightly set the brake then the tractor will stay running but the brake won't actually hold the tractor on a slope. I usually set the loader down either way to add some extra friction. Has anyone else had this problem? Any guesses on a solution?
   / Parking Brake Problems #2
Sounds to me like the safety switch that's attached to the parking brake needs a bit of attention. I would block the wheels for safety sake and slide under the tractor for a look see.
Be sure that the full motion of the switch is taking place when the brake is set.
Thanks, I'll try to take a look at that.
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2017 FREIGHTLINER CASCADIA TANDEM SLEEPER (A52576)
2017 FREIGHTLINER...
