Parking Brake dash warning light CK 35 / 4010 hst
   / Parking Brake dash warning light CK 35 / 4010 hst #1
dullpain
Platinum Member
Middle Tennessee
Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
Do you get a warning light on your dash when you set the parking brake and tractor is running ?
   / Parking Brake dash warning light CK 35 / 4010 hst #2
There is no parking brake warning light on my M6040 dash. I quit using the parking brake. Too easy to drive off with it still on. When I stop with the tractor still running - angle the grapple forward - lower to the ground & apply pressure - drop the rear blade to the ground.
   / Parking Brake dash warning light CK 35 / 4010 hst #4
My older DK5010 has the brake indicator and I took two photos up under the dash. The first overexposed (sorry) photo shows the brake lever going through the slot in the dash and two small bolts holding the brake switch. The second better photo shows the switch plugged into two barrow connectors.
The second photo is the important one. If your wiring harness has two connectors dangling where a switch would go then you may be able to get the indicator working. Start by connecting the two terminals together to simulate the switch closing and confirm that the brake light comes on (with ignition on). If it does, buy a switch at the dealer or on Amazon and you'll be good to go.
Let us know what you find and it will help other owners.
IMG_20190125_101545.jpgView attachment 617410
   / Parking Brake dash warning light CK 35 / 4010 hst #5
View attachment 617411View attachment 617410
THERE IS A BRAKE LIGHT ON MY DS4110 (2011) I ALSO DON'T USE IT MUCH-BUT I WORKS
   / Parking Brake dash warning light CK 35 / 4010 hst #6
Brake warning light works on my CK27. But it is really hard to see, and has never been useful as a reminder to disengage the brake.
Well I don’t know, my dash has a Parking Brake light, it lights up when you first turn on key, then goes out. My manual says that the Parking Brake light is supposed to come on and stay on if tractor is running and brake is set. Mine would be bright enough to be a good reminder. I’m forever driving off with the brake set so I need it. Guess I’ll talk to my dealer about it. Anybody else?
   / Parking Brake dash warning light CK 35 / 4010 hst #8
My dash has a parking brake light & also a 4x4 light that light up during the pre start test. Neither work after that.
   / Parking Brake dash warning light CK 35 / 4010 hst #9
   / Parking Brake dash warning light CK 35 / 4010 hst #10
My 2004 model year CK30hst has the parking brake light and it works. There is a small micro switch that works off the lever that locks the brake pedal. There is one or two dash indicators on mine that were never used by Kioti on my model but the same dash was used for other models and the light was wired for them.
   / Parking Brake dash warning light CK 35 / 4010 hst #11
KIOTI CK10 Tractors do not have a Parking Brake switch. You will only see the light when the key is turned to "on".
Hope this helps,
Thanks for the reply and link ThreePoint , and Michigan Iron. I guess if I want a brake light and 4WD Light I’ll have to wire it up
myself. Appreciate all the input.
   / Parking Brake dash warning light CK 35 / 4010 hst #13
Thanks for the reply and link ThreePoint , and Michigan Iron. I guess if I want a brake light and 4WD Light I値l have to wire it up
Yes, an odd attempt at cost savings? In WV if I'm moving I'm usually going up or down so I use 4wd and parking brake regularly. If I try to drive away with the brake on it is rather obvious, I guess because it is so new...? With regular use it becomes pretty automatic so I'm not missing the light...
   / Parking Brake dash warning light CK 35 / 4010 hst #14
Dullpain:. Can you confirm if you at least have a set of connectors on your newer CK to enable you to add a switch? Then also reply if/when you decide to jumper them together to test the light to your dash.
Since the 4WD indicator discussion came up, I would like someone with a working 4wd indicator to share a photo of the switch setup and where the connector is located. This is something that I would like to get working on my DK.
Thanks
PEJ5 - I’ll check it out and reply , but will be awhile.
   / Parking Brake dash warning light CK 35 / 4010 hst #16
There is a parking light on my CK3010 HST, but I don't ever notice it, so I end up driving with the brakes on. Sometimes I don't even see it till I'm back in the shed.
   / Parking Brake dash warning light CK 35 / 4010 hst #17
CreekFlats, very interesting. I know that Kioti offers some tractor models and features in some countries/regions, but not in others. Looks like your CK3010 HST is one example. I found it on Kioti's Australian website, but it's evidently not sold in North America. I'm wondering if the parking brake light switch on yours might fit, or be easily adapted to the North American CK3510 series. :scratchchin:
My 2018 CK35010SE HST has a parking brake light on the instrument panel that illuminates with the rest when the ignition is switched to "on", but, as Michigan Iron & Equipment posted, there is no switch installed to illuminate it when the parking brake is set.
Also, I'm wondering if your linkage might need adjustment on your parking brake. When my brake is firmly set, the tractor won't move! :no: So, as a practical matter, I don't even need an indicator light to tell me I forgot to release the brake. :laughing:
   / Parking Brake dash warning light CK 35 / 4010 hst #18
The brake setup is different on the regular CK10 models than the CK10SE models. On the regular CK10 model the brake pedal pivot is below the floor board. On the SE models, the pivot is above in the steering column.
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2018 Ford F-350 (A55973)
2018 Ford F-350...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
S/A Utility Trailer (A59231)
S/A Utility...
