Parking Brake dash warning light CK 35 / 4010 hst
/ Parking Brake dash warning light CK 35 / 4010 hst #1
dullpain
Middle Tennessee
Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
Do you get a warning light on your dash when you set the parking brake and tractor is running ?
/ Parking Brake dash warning light CK 35 / 4010 hst #2
There is no parking brake warning light on my M6040 dash. I quit using the parking brake. Too easy to drive off with it still on. When I stop with the tractor still running - angle the grapple forward - lower to the ground & apply pressure - drop the rear blade to the ground.
/ Parking Brake dash warning light CK 35 / 4010 hst #4
My older DK5010 has the brake indicator and I took two photos up under the dash. The first overexposed (sorry) photo shows the brake lever going through the slot in the dash and two small bolts holding the brake switch. The second better photo shows the switch plugged into two barrow connectors.
The second photo is the important one. If your wiring harness has two connectors dangling where a switch would go then you may be able to get the indicator working. Start by connecting the two terminals together to simulate the switch closing and confirm that the brake light comes on (with ignition on). If it does, buy a switch at the dealer or on Amazon and you'll be good to go.
Let us know what you find and it will help other owners.
IMG_20190125_101545.jpgView attachment 617410
/ Parking Brake dash warning light CK 35 / 4010 hst #5
View attachment 617411View attachment 617410
THERE IS A BRAKE LIGHT ON MY DS4110 (2011) I ALSO DON'T USE IT MUCH-BUT I WORKS
/ Parking Brake dash warning light CK 35 / 4010 hst #6
Brake warning light works on my CK27. But it is really hard to see, and has never been useful as a reminder to disengage the brake.
Well I don’t know, my dash has a Parking Brake light, it lights up when you first turn on key, then goes out. My manual says that the Parking Brake light is supposed to come on and stay on if tractor is running and brake is set. Mine would be bright enough to be a good reminder. I’m forever driving off with the brake set so I need it. Guess I’ll talk to my dealer about it. Anybody else?
/ Parking Brake dash warning light CK 35 / 4010 hst #8
My dash has a parking brake light & also a 4x4 light that light up during the pre start test. Neither work after that.
/ Parking Brake dash warning light CK 35 / 4010 hst #9
/ Parking Brake dash warning light CK 35 / 4010 hst #10
My 2004 model year CK30hst has the parking brake light and it works. There is a small micro switch that works off the lever that locks the brake pedal. There is one or two dash indicators on mine that were never used by Kioti on my model but the same dash was used for other models and the light was wired for them.
Kubota M4700 (A60462)
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
Giyi 12" Excavator Bucket (A60463)
Giyi 12" Excavator...
