Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck?
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #21
I'm not sure how accurate that statement is RayIN . So you're saying they all use a smaller pulley in the center ?
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #22
Ask AI how to align your mower blades...AI solves EVERYTHING! So does crypto. Buy bitcoin and other meme-coins.
AI Overview
MTD Genuine Factory Parts Original Equipment 3-in-1 Blade for 21 in.  Walk-Behind Lawn Mowers with a Bow-Tie Center Hole OE# 942-0741  490-100-M067 - ...
To properly align mower blades, ensure they are installed with the cutting edge facing the direction of rotation and the lift (or winged) edge facing up towards the mower deck. Additionally, the blade should be centered on the spindle and secured with a properly positioned washer. For riding mowers, the deck may also need to be leveled from side to side and front to back for an even cut. "
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #23
Even without any slip, minute dimensional differences in the pulleys would "un-time" the blades in a short time. Travelling at high RPM's even a thousandth of an inch, or a small amount of dust buildup would make a difference.
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #24
I always insure the valve stems on my inflatable mower blades are synchronized when I install them.
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #25
A multiple spindle mower deck belt pattern shows the middle spindle has much less belt to pulley contact than the outside spindle pulleys, making belt slip on the center one easy to understand.
Kinda got to disagree with you there.... At least on my two JD mowers....
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #27
That is a much better belt pattern than most multiple spindle decks.
Looks like my Husqvarna 54” deck belt routing.
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #28
Have someone told that it is not important on the belt driven blades?:cool:
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #29
You can time the blades all you want but they will not stay that way, the pulleys are suppose to be identical but there is enough variation in the manufacturing that they will turn at fractionally different speeds. Timing blades is OCD, IMHO
   / Parallel or perpendicular blade orientation when mounting 3 blades to a mower deck? #30
What an OCD perfectionist! Right side up, what's next, sharp too?;)
Doug in SW IA
My retired neighbor who mowed twice a week was really complaining about how his mower was cutting.
I had an atv/ mower lift and a cordless impact, so he brought his mower next door to my garage to change the blades.
I jacked up the mower climbed underneath the deck with the impact and started laughing.
He asked what was so funny, and I passed him out his first blade.
They used to be mulching blades. But were worn completely flat and extremely thin, and half the width of the new ones
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2004 DRAGON 150...
2015 Ford Focus (A51694)
2015 Ford Focus...
Oil Tank (A50775)
Oil Tank (A50775)
1067 (A53342)
1067 (A53342)
