Pallets in fields
   / Pallets in fields #911
Ok, I will also be an experimenter and will set up pallets in my field to see what happens . . . . Full circle . . .and this is how it started.
THE END.
   / Pallets in fields #912
It's getting so a pallet farmer can't try to establish a crop without a bunch of loons getting all into his business.
   / Pallets in fields #913
Another question in my mind... should 'Pallets' be capitalized or not?
Words for transcendent ideas in the Platonic sense, especially when used in a religious context, are often capitalized. Good; Beauty; Truth; the One.
As scientists, I believe we should avoid using "pallet" as a transcendent idea, and thus the lower case should be standard. There are obvious exceptions, such as when "pallet" is used at the beginning of a sentence (e.g., "Pallet formations have managed to flummox scientists for more than one month.") or in a title (e.g., the "Spurious 'Hayist' Theory of Pallet Formations").
Steve
   / Pallets in fields #914
Suppose they want Government Subsidies too?
   / Pallets in fields #916
Okay tomorrow I'll set up another set a few hundred feet away to test this .. Hey at least I'm actually experimenting ...
If a bird deposits on the pallet this time we might have a whole new theory. The combination of coyote pee and bird doodoo could add at least 3 pages to this thread.
   / Pallets in fields #917
In the interests of science I will continue my investigations
P.S. In all this time that single eye never blinked..
Be careful out there. If you smoke, run for your life if the one-eyed creature does blink. The front of the creature resembles the hindquarters of a Capra aegagrus hircus. These creatures produce methane, often in prodigious quantities. Recall Bubba's Law: methane + lit cigarette/cigar = blooey.
Steve
   / Pallets in fields #920
I must concur that previous squirrely posts (Wagtail, lilranch, James, and think TomSeller also must be thrown in)... should be considered before casually issuing these advanced optical devices. As such, I think the lot of them have demonstrated that the 'lure to lurk' might be too much for them to remain focused on the scientific objective.
More vetting is necessary... due diligence must be exercised! For one, anyone who has applied for a TSA screener position, especially after the introduction of the original millimeter wave scanners in 2007 should be summarily disqualified. I think however I should be promoted to near the front of the line as I have demonstrated to date, that I have no desire to use them inappropriately.... and can be trusted... at least until the mystery is solved! :D
Oi! At no time have I ever condoned the Squirellist Theory.
Indeed, I am the only member of this Fellowship of the Pallet [FOTP] to have presented any sort of tertiary qualification to be entrusted with this delicate apparatus! As a serving RAN Reservist, I hold a Top Secret security clearance which would guarantee that the device would not be used in a nefarious way. I clearly stated that "observing ladies 'naughty bits'" was a standard operating procedure [SOP] to calibrate the Professional X-ray Glasses... nothing more.
As a fellow TBN MOTM [Member of the Month], I am surprised at your insinuations! Especially as a veiled attempt to advance yourself 'up the queue' for access to this technology.
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2017 Toro Workman HDX Diesel Utility Cart (A59228)
2017 Toro Workman...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
