Pallets in fields
   / Pallets in fields #391
Curiosity has the better of me and I posting with the hope of learning the reason for the pallets.
Eddie
   / Pallets in fields #392
I'm thinking'...
   / Pallets in fields #393
Eddie
we have been waiting for weeks, haven't learned a whole lot yet.:)
   / Pallets in fields #394
You kidding me!? I learned all kinds of useless things.
   / Pallets in fields #395
I have seen a lot of fields get planted and generally the farmer fills up in the same place (on the side of the field) so as to refill the fertilizer tanks/bins at the same time as he fills the seed hoppers. As such, I don't think that your supposition will fit these pallets.
Aaron Z
In addition, the "Seedists" should also have to explain the following.
The pallets appear in late fall and disappear in early spring according to the OP. What crops are planted in the late fall? Depending on how you define "late," only small grains and canola come to mind amongst the agronomic crops. Amongst horticultural crops, beets, broccoli, carrots (AKA carets), kale, peas, and spinach come to mind.
1. The OP provided us with photos of the pallet formations as of late December. Would we not expect to see some evidence of the germination and growth of fall-planted crops (either agronomic or horticultural) in those photos?
2. Why would farmers wait until spring to retrieve the pallets and thus do damage to fall-planted crops?
3. In my experience, a relatively small amount of seed is required relative to acreage. This is especially true for some of the horticultural crops. What crop uses a seeding rate that would require two pallets of seed every 500-700 feet?
Steve
   / Pallets in fields #398
Steve
Excellent points. The only one that I know of would be something like Bermuda grass which gets "seeded" with sprigs...
Aaron Z
   / Pallets in fields #400
I think the key to the mystery is (as has been mentioned) that they are (or do not appear to be) actual pallets...
They do not appear to be typical pallets like you get when you buy a "pallet" of fertilizer, lime etc.etc...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
200 Gallon Tank (A57148)
200 Gallon Tank...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56438)
Greenworks...
