Front-End Loader Pallet forks. Question problem.
/ Pallet forks. Question problem. #1
radartech2
Kubota L3400
Hey folks... I’ve been kinda busy and haven’t had time to search... so I’ll ask...
I have new pallet forks for my kubota 3400–
WRlong lightweight set on a quick attach...
But I find they slide side to side a lot and flip up more than I like...
Is there a way to secure them ?
Ideas? Quick ones at that...
Thanks
/ Pallet forks. Question problem. #2
put a limiting chain from the root of both of the 3 point arms to the ball end on the other side, this will limit side to side movement
/ Pallet forks. Question problem. #3
After looking at the website picture and reading the description the only thing I could recommend is trying to secure them to the bottom frame of the back guard. A bungee would be enough to keep them from bouncing around while driving without a load on them. My QA forks have a locking pin on top of each fork to keep them set in place.
/ Pallet forks. Question problem. #4
Hey folks... I致e been kinda busy and haven稚 had time to search... so I値l ask...
I have new pallet forks for my kubota 3400?br>WRlong lightweight set on a quick attach...
Thanks
I am guessing that you have pin top forks like these:
I use chains on mine:
Hose clamps or muffler clamps on the shaft will keep them from sliding sideways.
I like that chain idea.... and yea. Muffler clamps... I should have thought about that!!
What did you do? Just run a bolt thru the chain to hold it in a loop? Or those quick links with the threaded “nut”?
/ Pallet forks. Question problem. #6
Just a short chain with a bolt and nut :thumbsup:.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
3ft Metal Star (A65583)
3ft Metal Star...
2022 EZ-GO ELITE...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
