Pallet forks for your tractor
   / Pallet forks for your tractor #61
Huh. I've had Titan pallet forks on my JD 3320 tractor for several years, and they've done real well for me. Then again, I just use them here around the house and horse barn. I don't run a warehouse.
Last fall I also purchased a hay spear frame & spears from Titan to handle large square bales (800+ lbs) and am equally happy with the frame/spears and their service - especially with the help they provided over the phone to make sure that I got the spears that I needed.
I'd buy again from them without hesitation.
My backing plate is tearing away where the brackets for the forks are welded, but I moved a lot of wood with them in the 2 years since I bought them. I will probably mount the forks in my bucket and trash the rest.
   / Pallet forks for your tractor #62
I can't see that problem EVER occurring with my EA forks!
But then.....my EA forks did cost a good bit more than Titan forks would have.
   / Pallet forks for your tractor #63
You get what you pay for.........:)
   / Pallet forks for your tractor #65
   / Pallet forks for your tractor #67
Buy once, cry once? Is that the old saying?
Exactly right. However, once the plate started bending and I knew that it was toast anyways there may have been a bit of excessive abuse involved... they really weren't designed to be digging out logs which were frozen in the ice. ;)
   / Pallet forks for your tractor #68
My B3030 came with clamp-on-the-bucket forks. They are very handy. Several hundred percent better than none at all.
But you lose a LOT of lifting capacity because the COG moves so far out front. I didn't have SSQA, so I bought an adapter and a set of SSQA forks and what a difference!
I guess it boils down to your needs, desires and circumstances.
   / Pallet forks for your tractor #69
In my opinion it is silly to not have a pair of pallet forks if you own a tractor. SO many uses, pay for themselves in no time.
I agree. I probably use my forks as much as I do the bucket. I bought one of the Titan pallet fork/bale spear SSQA combo's. My forks are the 42" model. It was money very well spent.
   / Pallet forks for your tractor #70
Sawyer Rob's setup is pretty slick, and it's what made me hold off on a potential grapple purchase. I realized most of the stuff I'm doing I need pinpoint precision for. The forks/grapple combo does that very well.
A friend of mine (R.I.P.) gave me a set of forklift forks from his job a few years ago. Heavy duty, I need to modify them and make them quick attach, and also make my loader QA. I plan to build a grapple for this setup and use it like crazy.
I also need to build more roll-back into my setup, it has hardly any in stock form. ('64 MF35 Utility)
2019 Autocar ACX Xpeditor T/A EZ-Pack 40 Yard Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
2021 CATERPILLAR 226D3 SKID STEER (A52707)
2021 CATERPILLAR...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2015 Toro Reelmaster 3 Gang Mower (A55851)
2015 Toro...
Caterpillar D5G (A53317)
Caterpillar D5G...
