Pallet forks add on D rings for lifting...
   / Pallet forks add on D rings for lifting... #1
Buckgnarly
Platinum Member
West topsham VT
Kioti DS3510
Wanted to get a plate for simple lifting purposes, but realized that I could do the same with my pallet fork plate. I wanted to eliminate the forks for lifting stuff, so I added some D rings on the outside. After some thinking, it seems the outside was the best place to avoid intereference with the forks themselves...
Pics...1/2" x 2" x 2" angle iron gusseted with 1/4" x 3" strap...
Final product..
Also, compliments of a member on garagejournal, I found out that Channellock makes a set of "welpers" now...model 360 if anyone is interested in a great US made set of welding pliers...
Made some skid shoe mounts for my new Meteor....pics and more details if anyone is intereseted...
   / Pallet forks add on D rings for lifting... #2
Nice feature, did you build your pallet forks?
Dave
   / Pallet forks add on D rings for lifting... #4
Very nice! I have a set of 48" Bobcat brand forks that I picked up on eBay. I believe I may make the same modifications. Thanks for sharing.
   / Pallet forks add on D rings for lifting... #5
he buck your over here also .....lol nice tractor I'm buying a LS R3039H with FEL and 4in one bucket
Jeff
   / Pallet forks add on D rings for lifting... #6
Like a pocket on a shirt!
   / Pallet forks add on D rings for lifting... #7
Final product..
Welding on chain hooks also works well.
Jeff
HA! Small world!
I thought about those, but they don't work well with lifting straps and I already have 3 on my bucket. For lifting I use my straps and I can still use chains with the d rings.
   / Pallet forks add on D rings for lifting... #10
I've used the weld-on D rings quite a few times too, and they work very well.
Funny thing is, right above them on the shelf at the local steel supply is a label from the manufacturer stating that D rings are not suitable for lifting or use in any overhead application whatsoever. Tie-down/lashing applications are the only *approved* duties as per the manufacturer's literature....
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
Informational Lot - Financing (A52748)
Informational Lot...
Mahindra 2516 Compact Tractor w/Loader (RUNS) (A50774)
Mahindra 2516...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
