Pallet Fork Length
   / Pallet Fork Length #21
Kind of interesting that most of the discussion is about being able to see the fork tips rather than about lifting.
The OP has a Kioti 2610, a sub 25 h.p. tractor. I doubt lifting capacity of the forks is even a factor. The cheapest forks I could find will lift over a ton, so capacity wouldn't be a factor until you get over 50 h.p.
   / Pallet Fork Length #22
I have 42" forks that I can't see well. For this plowing season I installed front and rear cameras which will make seeing the forks easy - just haven't tried them with camera yet.
   / Pallet Fork Length #23
I have a set of 42" forks as that's what was in stock when I went to purchase a set. I also made a set of extensions, extending them to 6' for moving powersport machines around the yard.
   / Pallet Fork Length #24
I have 48" forks and am satisfied with them most of the time.
I have considered some slip on extensions for loading trailers when I want the pallet a long ways from the tailgate,
pickups I can get a pallet most of the way forward without extensions.
   / Pallet Fork Length #25
get 48", then push come to shove, you can always trim them down.
   / Pallet Fork Length #26
42".
Initially thought I wanted 48", but after reading some comments here and there, and due to a small cost savings I went with 42". Glad I did. They don't stick through past pallets, and IBC's when I'm stacking next to each other and less chance of me punching through a wall.
I went with 42" for this reason, but kind of wish I had gotten 48". I think they'd be easier to line up, and I wouldn't feel like I have to push all the way against the pallet and slide it to make sure I had a good grip. I've never tried the 48", so it might just be a "grass is greener" situation.
   / Pallet Fork Length #27
I bought 48" and would do so again.
I've idly toyed with the idea of buying a second pair in the shortest length and cutting them down, each one differently, for those times I want to pry or dig or lift something that only wants one stubby fork. An example would be lifting a felled tree trunk from the side, which a long fork is more hinderance than help, and likewise two forks. If I saw a pair at a yard sale for cheap I'd do it, but I'm not at the level of ordering.
   / Pallet Fork Length #28
My 36" forks are too short for about 1/25 jobs around my hobby farm (moving junk or big hay bales). That said, I have driven them through the barn wall, so shorter would have been better in that one instance.
   / Pallet Fork Length #29
Generally fork lifts are used in warehouse situations and as such 42" was the most popular.
As long as the forks are over 50% of the pallet size you are good.
Long forks in narrow warehouse isles are accidents looking for an accident.
Now consider the majority of pallets are usually under 48 x 48 inches the 42's do the trick.
I was, for a time, in that industry and sure visited my share of warehouses and saw many unique situations.
There are times when you can't get your forks completely under something and have to lift and drag it until you can.
If you're unloading a trailer, a truck, especially a bigger truck, something shoved into a corner in the barn.
As to putting a hole or a dent in the barn, I don't need 48'' forks to do that.
I'm kinda leaning toward the 48''s. Maybe I'm wrong but I haven't read enough bad things about them to change my mind.
NEW Woods 6ft Finish Mower (A55315)
NEW Woods 6ft...
(2) SLIP ON 76" FORK EXTENSION (A57193)
(2) SLIP ON 76"...
2021 KOMATSU D71PX-24 CRAWLER DOZER (A52707)
2021 KOMATSU...
2020 16ft. T/A Flatbed Utility Trailer (A55853)
2020 16ft. T/A...
Pallet of 3' LED Lights (A56469)
Pallet of 3' LED...
2015 Dodge Journey Van (A55853)
2015 Dodge Journey...
