WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 15,450
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
I need to get a new set of pallet forks to go on my Deere 320R loader, and there are plenty of options out there, with most of the best prices showing up on eBay. Unfortunately, when one seller just has frames and another just has forks, I'm having trouble figuring out if they'd be compatible. It appears they're all made to the same standard and interchangeable, but there's just not enough information available from the sellers to really say for sure, and return shipping on stuff this big and heavy gets unattractive real quick.
Titan Attachments appears to have all the same stuff, literally identical with the exception of a few stickers, but their prices are substantially higher -- like 50% - 100% higher -- for what appears to be the same exact item.
Here's a frame I'm considering, available from two different sellers on ebay, and also at Titan Attachments:
On this particular model, the Titan version has three additional sockets welded to the frame for bale spears (no need here), but is otherwise the same size, weight, and design.
Here's a set of forks:
I emailed each of the frame sellers, and none could tell me if these or any other forks could fit their frame. One couldn't even tell me the weight capacity rating for the frame, they're just resellers importing and selling.
There are frame + fork combos on eBay, but none with a hitch receiver, and most are the taller frame that would be more difficult for me to store.
Anyone go thru this before, and determine they all fit with one another? No one is posting the critical dimension between the cleats or mounting rails, just useless stuff like overall height.
For John Deere Pallet Fork Frame Only Attachment, Rated 3,000 LB, Receiver | eBay
For 200, 300, 400, and 500 series John Deere loaders. (USA only, Does NOT include Hawaii, Alaska or Puerto Rico, PO Boxes/APO's). Material: Steel. Color: Green.
www.ebay.com
2 Packs 48" Pallet Fork Blades Forklift Blades for Skid Tractors Loaders 4000lbs | eBay
Skid steer pallet fork blades can easily carry heavy loads, empowering you to tackle the toughest jobs. It has superior carrying and towing capacity with a carrying capacity of up to 4000 lbs. The pallet fork blades can be used to lift and move construction materials, debris, and broken fences...
www.ebay.com
