Painting the Plastic hood and parts on a old 240
   / Painting the Plastic hood and parts on a old 240 #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I've a old 240 Garden tractor and the paint is pretty faded and would like to paint it, but, would it stick to the plastic hood and some the trim pieces? I would primer first and then color. OR would I just be wasting my time? Does anyone have experience with paint on these tractors? bjr
   / Painting the Plastic hood and parts on a old 240 #2
I would clean the parts good to remove any traces of oil or silicone, then I would scuff the parts with a 3M Scotch Brite pad or equal. I do not think I would use primer, but it is up to you. If you use quality paint it should stick just fine.
Good luck,
Ken
   / Painting the Plastic hood and parts on a old 240 #3
It takes a special paint to paint plastic. Visit a Automotive Paint supply house in your area and discuss what you want to paint with one of the personnel. Sherwin Williams sells good automotive paint. If you visit a Sherwin Williams Store make sure it one that specializes in automotive paints and not one that sells only paint used to paint structures.
   / Painting the Plastic hood and parts on a old 240 #4
Good luck,
Ken
I agree with this and would choose an enamel paint most likely, need a paint that can bend a little without fracturing. I would stay away from laquers which harden with age. I would be inclined to use Ken's approach to prep and use the Deere enamel probably need the older classic color of green anyway.
   / Painting the Plastic hood and parts on a old 240 #5
You WILL need a flex agent mixed into the paint.
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
201930 (A54756)
201930 (A54756)
