Painting the Plastic hood and parts on a old 240
   / Painting the Plastic hood and parts on a old 240 #1
bjr
Eastern WA
Jinma JM354
I've a old 240 Garden tractor and the paint is pretty faded and would like to paint it, but, would it stick to the plastic hood and some the trim pieces? I would primer first and then color. OR would I just be wasting my time? Does anyone have experience with paint on these tractors? bjr
   / Painting the Plastic hood and parts on a old 240 #2
I would clean the parts good to remove any traces of oil or silicone, then I would scuff the parts with a 3M Scotch Brite pad or equal. I do not think I would use primer, but it is up to you. If you use quality paint it should stick just fine.
Good luck,
Ken
   / Painting the Plastic hood and parts on a old 240 #3
It takes a special paint to paint plastic. Visit a Automotive Paint supply house in your area and discuss what you want to paint with one of the personnel. Sherwin Williams sells good automotive paint. If you visit a Sherwin Williams Store make sure it one that specializes in automotive paints and not one that sells only paint used to paint structures.
   / Painting the Plastic hood and parts on a old 240 #4
Good luck,
Ken
I agree with this and would choose an enamel paint most likely, need a paint that can bend a little without fracturing. I would stay away from laquers which harden with age. I would be inclined to use Ken's approach to prep and use the Deere enamel probably need the older classic color of green anyway.
   / Painting the Plastic hood and parts on a old 240 #5
You WILL need a flex agent mixed into the paint.
434669 (A48836)
434669 (A48836)
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2011 Western Star Trucks 4900 Tri Axle Truck, VIN # 5KJNALDR4BPBA7822 (A54865)
2011 Western Star...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
