Painting the Plastic hood and parts on a old 240
   / Painting the Plastic hood and parts on a old 240 #1
bjr
Eastern WA
Jinma JM354
I've a old 240 Garden tractor and the paint is pretty faded and would like to paint it, but, would it stick to the plastic hood and some the trim pieces? I would primer first and then color. OR would I just be wasting my time? Does anyone have experience with paint on these tractors? bjr
   / Painting the Plastic hood and parts on a old 240 #2
I would clean the parts good to remove any traces of oil or silicone, then I would scuff the parts with a 3M Scotch Brite pad or equal. I do not think I would use primer, but it is up to you. If you use quality paint it should stick just fine.
Good luck,
Ken
   / Painting the Plastic hood and parts on a old 240 #3
It takes a special paint to paint plastic. Visit a Automotive Paint supply house in your area and discuss what you want to paint with one of the personnel. Sherwin Williams sells good automotive paint. If you visit a Sherwin Williams Store make sure it one that specializes in automotive paints and not one that sells only paint used to paint structures.
   / Painting the Plastic hood and parts on a old 240 #4
Good luck,
Ken
I agree with this and would choose an enamel paint most likely, need a paint that can bend a little without fracturing. I would stay away from laquers which harden with age. I would be inclined to use Ken's approach to prep and use the Deere enamel probably need the older classic color of green anyway.
   / Painting the Plastic hood and parts on a old 240 #5
You WILL need a flex agent mixed into the paint.
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
2019 TAKEUCHI TB290 EXCAVATOR (A52705)
2019 TAKEUCHI...
2022 CATERPILLAR 303.5CR EXCAVATOR (A52705)
2022 CATERPILLAR...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
