Painting my implements to match tractor
/ Painting my implements to match tractor
Similar drive as you, I bought older used equipment and want it all color matched to my machine. So I clean them up, wipe them down with denatured alcohol, wipe grease areas with acetone, and slather on Rust-Oleum with a brush. It leaves a little bit of lines in the areas that I flood to deep, but I am okay with that.
I also order the stickers for brands and models, I just paint around the safety ones since I don't care much about them.
I know that I do not get spray finish quality, but I am very happy with the finish I do get. I have painted a good deal with the Rust-Oleum gallons and it always impresses me with the thick paint and how it covers and then how is lays itself smooth over night. It does take a few days to dry, so I leave the item in the garage for a few days while I wait for it to get hard. I don't use hardeners or anything, I just open the can and start brushing. It is a very forgiving paint for not so clean surfaces or dirt. Just paint the light/fine dirt/oil right in to the finish!
Nice job also! Doesn't look brushed on from here!:D:thumbsup:
My two neighbors laugh at me for washing my tractors after using them, but I do a lot of spraying with sulfur and other fungicides.
Someday, I may want to sell them, and can’t help but think the overall condition of the sheet metal will be a factor in attracting a buyer.
I keep hearing good things about the HF paint gun, I think I will try one out on my 25 year old scraper, if it turns out badly, It won’t ruin my day. Got one blue tractor, and one green one, so have to decide what color to use.
Definately have to go BLUE!:laughing:
I do the same with brushed on Rust-Oleum, I'll do a coat of paint one evening and then wait until the next evening to slather on the next. It also takes Rust-Oleum a couple days before I would even consider moving the part outside. In the case of this mower, I'll leave it in the garage until this coming Friday or Saturday and that will be 4-5 days in a dry/heated garage before it goes out to meet the sun and rain. I will not put wax (synthetic sealant) on it for a couple months. I do actually wash and wax my tractor, garden tractor, implements, vehicles. I don't know why, but seeing water beading up on paint makes me all warm and fuzzy inside :)
Your not alone with washing/waxing your equipment. Last week, I just cleaned all the greasy areas, washed, then waxed the tractor. Nice and shiny! Even UV protected all the boots, plastic, and the seat.
/ Painting my implements to match tractor #24
Thanks. I will copy and paste your instructions. I used to use regular sprayers but later found that using the ones with bottle on top worked better for thick tremclad. Thin it out and you loose the shine.
I too use the "on sale" sprayers from Princess Auto (Equiv of HF). For a while, I was even returning them. Went back to the store to purchase the internal filter which is never available. Oh, well, then I want my money back. No problem.
/ Painting my implements to match tractor #25
Last couple ofpaint jobs I did I used lacquere thinner with rustoleum . That made it dry a lot faster . Can recoat in about 2-3 hours. Hardened nice laid flat. Might try the magic hardner next time.Just fond lots of good info on the H.A.M.B. jalopy journal .:drink:
/ Painting my implements to match tractor #26
I used that same Majic paint and hardened to paint my old Berti flail mower. I couldn’t bear putting it on my brand new (at the time) LS. Sprayed with a 15 year old HF HVLP gun and it turned out well. Painted it on the 4th of July and let it sit for a week before using it. The mower is kept inside to help prevent dry rot on the hoses, so I don’t know how well it will resist fading.
Before.
After.
/ Painting my implements to match tractor #27
Nice to know now that I'm not totally weird.....
Something about water beading off of it brings a sense of ah, she's protected.
Plus I use 303 on the tires as well as hyd. hoses and all things not metal.
Good UV protection and the tires don't track as much debris into the shop when it's time to park it for the night.
Before.
After.
Nice work! Made a big difference in the look. There's just something about color matched implements.
Haven't tried the 303. Do you think it is the best for our tractor needs...your thoughts
/ Painting my implements to match tractor #30
It's the best UV protection on the market. It's very well known in the auto detailing crowd.
/ Painting my implements to match tractor #31
303 is the best UV protection you can get. The only downside is it must be reapplied every 90 days.
/ Painting my implements to match tractor #32
I follow a channel called sweet project cars. He's as cheap as I am. So I treated wiper blades and tires.
Wiper blades after 3 months of S. Texas sun still holding up well. Will treat them about every 6 months if I remember heh....
Use on Travel Trailer as well. well most anything needing UV protection.
the black clay did not stick to the tires as much as they used to when I treated the CK.
Will coat all things not metal on the NX when I get caught up with cleaning up roots and junk from the huisache plowing and reseed an acre for food plot.
Oh and find me a bottle of spray on polish for all things metal. I like to see water bead off the rims and hood. Plus when wheels get muddy and nasty the stuff seems to wash off easier. Hate using a power sprayer, to much electronics to chance it.;)
/ Painting my implements to match tractor #33
Meguiars Proffessional line, Synthetic X-press spray wax,
It's not a replacement for your real sealant, but for 2-3 weeks you will bead and be protected. It's intended as a topper, or a maintenance product used to boost/enhance your properly sealed finish. But it's an amazing product (short service life though) for wheels, glass and trim as well as the entire paint job. I buy 6 gallons at a time, I use it on everything but my wife.
I use it on my stainless appliances, my shower stall and glass door, my black marble counter tops. Oh, and I use it all over my cars and trucks!
This is life changing.
I buy locally at Pittsburgh's Premier Car Care Store for detailing supplies, equipment and accessories. - Autoality Incorporated , he will discount down to around $25 a bottle of your buying bulk/case quantity. I'd call T at Autoality and see if you can work a deal for 4 gallons shipped.
Meguiar's D15601 Synthetic X-Press Spray Wax - 1 Gallon Amazon.com: Meguiar's D1561 Synthetic X-Press Spray Wax - 1 Gallon: Automotive
/ Painting my implements to match tractor #34
I too would like to hear your recipe in detail. I have painted lots of stuff with enamel but never used additives.
Curious if anybody knows. You can have something sandblasted but if there were rust blisters, these still show through the fresh paint. Any (easy) way of hiding those?
There is a product used in body work called red lead aka skim putty :Robot Check
/ Painting my implements to match tractor #35
Good job:thumbsup: What brand paint ,hardner, spray gun. What was your ratio .? How did the paint harden? I ve have been painting tractor projects and restoration stuff for years and I still suck at paint. Mainly use rustoleum with mixed results. Some get hard some you could scratch your name into it with your finger nail.:mad:The worst thing is they all seem to fade way to fast . I tried tsc implement paint and that came out the worst.Like to hear your formula.:drink:
In my experience Tremclad does not fade so you might try it next time.
/ Painting my implements to match tractor #36
I looked at Tremclad after you mentioned it and the MSDS sheet pulls up its manufactured by Rustoleum in Canada. Wonder if it's a different formula mix.
/ Painting my implements to match tractor #37
Does not surprise me.
At one time Sico made all the paints in this area as they had a big installation. Sherwin Williams were real big 20 years ago but almost disappeared but suddenly are back in the picture and now own the former Sico factory.
Kind of interesting to see that the manufacturer of a very high volume lower priced product also produces his compeditor's low volume higher priced one as well.
I have also noted that brands come and go over the years and also they all have their similar seasonal promotions, like 4 for 3.
Today it is all about chemistry, and very specialized at that.
Around here we only can get water based now.
And yes formulas do vary a lot. An uncle was a commercial artist and knew what to add to paint to create whatever drying time suited the application.
Sign painters need very opaque and very fast drying along with specific floss.
KIVEL 48" MINI PALLET FORKS (A60430)
KIVEL 48" MINI...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
43018CFL (A59228)
43018CFL (A59228)
2021 Chevrolet Express Cargo Van (A59230)
2021 Chevrolet...
