Paint or Stain on Shed
   / Paint or Stain on Shed
That's weird, the prices I gave I just looked up at Lowes in Alexandria.
The ones I was looking at was James Hardie primed Hardie sheets.They had something else called smart siding that was cheaper. I am not sure.
   / Paint or Stain on Shed #12
I would paint it with the best quality exterior latex you can find at a paint store like Sherwin Williams. It should last 10 plus years. Stain will need re-applied. But that is me, I'm lazy and don't like to paint or stain and I'm too practical to care about the looks of stain. I like the look of paint better anyways.
Comes down to looks over practicality. Good paint will protect better than stain if you keep it painted when needed.
   / Paint or Stain on Shed #14
In my experience, stain needs re-application more frequently than paint (assuming equal level of quality materials). I prefer the look of real wood/stain over paint. However, I'm not getting younger. We are using metal siding. Will not need replacement until I don't care anymore.
   / Paint or Stain on Shed #15
Kind of depends on the look you want. Stain is more "rustic". Paint will probably last longer if it's properly applied. Since most paint is latex, if there is any poor surface prep, it will peel or bubble. It just can't adhere as well as oil based. I agree with Torvy, I would only do metal on a shed.
If you do go with T-11, consider the lower edge sealing carefully. I would prime/stain the inside of the lower portions before installation because you almost always get some moisture there and eventually it will affect it.
   / Paint or Stain on Shed #16
go stain, Cabot premium grade. & go solid pigment, not semi transparent for full weather/ uv resistance.
water based is vastly improved today, i feel superior to oil based. i read where oil based is not recommended for horizontal decks, etc, though your application sounds mostly vertical. regards
  • Good Post
Reactions: JJT
   / Paint or Stain on Shed #17
That's why I went with cement siding :)
   / Paint or Stain on Shed #18
I tossed paint and stain back and forth as I was building my shed. I ended up painting mine. To match my shop, which matches my house. I rented a paint machine from Kelly Moore, and used their mid grade paint, got a color match for free. Was very easy and fast, it's been two years still looks awesome.
   / Paint or Stain on Shed #19
T1-11 isn't a great product for siding. It's almost impossible to stop it from absorbing water and rotting away. It's big selling point is it's price and ease of installation. If you are committed to using it, then protecting it is critical.
Stain soaks in and then slowly fades away. When new, it offers decent protection at keeping moisture out, but it's a ticking clock that will require additional applications on a regular basis depending on your climate. Usually it starts to fall apart at the bottom.
Paint provides a barrier that keeps moisture out, but T1-11 is a sponge that makes it harder then most materials to get a really good paint job. Primer and caulking is critical. It will soak into the wood and provide a stronger bond for the paint. Zinsser is my favorite primer. A good quality paint makes a difference. I think Valspar Duramax is the best for the price in exterior paint, but Sherwin Williams and Kelly Moore both make excellent exterior paints for more money.
I haven't installed T1-11 in well over a decade. I tell my clients that I can't warrantee, and that it requires constant maintenance to keep it protected. Even with the best paints, it will crack and open up fairly quickly, and require additional painting to protect it. In every case, they agree to spend a little more for SMART siding, or even better, go with Hardie.
SMART is a high grade OSB that is stronger and denser then the construction grade OSB that is used on houses for sheathing. It has a solid finish that keeps moisture out and hold paint very well. It cuts and installs just like any other wood product.
Hardie is cement based, it's bug proof, fire resistant and it holds paint better then anything else. It's draw back is requiring a special blade to cut it, and it's fairly weak which leads to breaking when handling. It requires a backer of some kind when installing. Usually OSB, and house wrap, or ZIP Siding. It's more labor and money to install it, but when it's done, you never have to mess with it again.
   / Paint or Stain on Shed #20
I built a 10x16 shed and sided it with T1-11. Never again! For all the above reasons and it is a tuff job if painted with a brush and roller. It really drags. I feel it is a must spray product.
Metal is the way to go in my opinion.
20' Container (A53316)
2009 Nissan Versa (A47477)
2009 Nissan Versa...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
New/Unused Quick Attach Rock Breaker (A54865)
New/Unused Quick...
John Deere 4045 Power Unit (A53316)
John Deere 4045...
2018 John Deere 260E 25 Ton Articulated Off-Road T/A Dump Truck (A55787)
2018 John Deere...
