Paint And Method
/ Paint And Method #31
I would prime the wood first. Otherwise the wood is going to soak it in like a sponge. You can spray or brush, your choice. As for hardener, it helps single stage paint stay glossy. Without it, it fades out right away
/ Paint And Method #32
For implements that will be drug around in and through the ground, I use Dupont Industrial Imron 2.7 pr (primer) and 3.5 HG. Used it on a backhoe bucket and it's held up great digging. Toughest stuff I've found. I spray it with a pressurized gal pot and an HVLP gun from Hobo-freight. Good enough for implements ! But a supplied air helmet or 1/2 face mask with goggles is needed due to the hardener.
FYI - hardeners have pretty much the same stuff as super glue. It's activated with moisture. When you breath it, it will coat the little tiny openings in your lungs and seal them off -- permanently. It's like getting an instant permanent asthma attack that CAN'T BE CURED short of a lung transplant. Do not spray hardened paints without proper safety equipment.
For a tractor touch up, color from the mfg is good sprayed out of a touch up gun.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2011 Ford F750 Bucket Truck (A60352)
2011 Ford F750...
TraxMax Stand-On Tracked Sod Installer (A59228)
TraxMax Stand-On...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
2014 International Maxxforce DT (A53317)
2014 International...
