Oxygen regulator problem
   / Oxygen regulator problem #1
MillWeld
Durham NC
Ford 641
I wheeled out my oxy-acetylene cart and opened the oxygen tank valve and the relief valve immediately opened. Did it repeatedly. Is wiser to repair/replace the relief valve or just buy a new one? It is a Victor Equip Co. unit.
   / Oxygen regulator problem #2
You should take it to a gas supplier and have it rebuilt. BTW,where did you see "regulator relief valves" for sale? I didn't know there was such thing.
   / Oxygen regulator problem #3
Just curious, but what does a relief valve downstream of the shutoff valve do (i.e. what does it provide "relief" to)?
I saw "regulator relief valve parts" on a search but never a supplier.????
The relief valve relieves excess oxygen pressure as a safety precaution. Mine is obviously defective - failed abruptly.
   / Oxygen regulator problem #5
The supply shop should beg able to get you a ball park figure to repair them. It’s usually well worth the effort.
   / Oxygen regulator problem #7
You might have a piece of trash stuck in your high pressure inlet valve. ( it's the center part inside your regulator that the diaphragm and spring pushes against.) The pressure climbs until it vents. Eventually, your diaphragm will rip. I guess you have real victor and not the economy line?
Does your nipples have the porous brass filter on the id? I crack the cylinder valve to blow dust away before mounting my regulator. The little viton seals eventually wear. It may just be time to rebuild.
   / Oxygen regulator problem #8
most of the ones I have looked at replacement is usually faster and easier, and the cost is not that much more, for many regulators,
   / Oxygen regulator problem #9
If he has a reseating pressure relief, he bought the premium stuff like SR450D. Expensive and worth rebuilding.
Mine is a Victor SR250C. I saw a Utube video of someone installing a repair kit on the exact model so I purchased the kit. Hope it is worth the effort.
2014 Dodge 5500 4X4 Bucket Truck (A53472)
2014 Dodge 5500...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2008 KOMATSU D39PX DOZER (A52577)
2008 KOMATSU D39PX...
