Owner built PT attachments?
/ Owner built PT attachments? #2
Do you want repeats of what has already been shown? I attached a picture of my 2 inch receiver with the approximately 7 foot boom pole in it.
It would be cool to find all the great ideas in one thread as we are such a small part of TBN...
/ Owner built PT attachments? #4
I would love to see some home built attachments if anyone has time?
I tried to build a grapple for my bucket, but the cylinder was too strong and the bucket not reinforced enough, so it ripped out every time I tried to grab something. :p So, no pictures for the failed project.
This, however, works well. My $10.00 soil slicer. :) I works great for edging ball diamonds, slitting sod to make square edges, etc... What's nice is I can just drive forward and run a line where ever I want. I can see where it is going real easy. If the soil is hard, I can make a 1" deep cut, then re-trace it exactly at 2", 3" etc... that's the beauty of the out front attachments. :) I was going to add a cable puller to the rear of it to pull low voltage lighting cable once the trench is done, but I have not had the need as of yet. Since these pictures were taken I added a 2" receiver hitch to it and use it to move my trailer around if needed. I may end up adding a 2nd 2" receiver pointing down and fasten the plow share to some 2" stock to make it removable.
/ Owner built PT attachments? #5
Let's see what else I have.
/ Owner built PT attachments? #6
And here is a link to a rather long thread about a backhoe that I am building for the last two years. I just need about 10 straight hours and a couple hundred bucks and I'll have it done. But with the kids being so active, I get no daylight hours in a row to drag it out and finish it. :rolleyes:
/ Owner built PT attachments? #7
I'm pretty sure there's a thread about this subject, somewhere back in the dust and spider webs. Maybe somebody can find and resurrect it?
/ Owner built PT attachments? #8
I really like that boom pole and the idea of plugging it into a receiver. :)
Construction details, please.
/ Owner built PT attachments? #9
Basically, I took three 2 inch receiver tubes and welded one to the center of the quick attach plate pointing forward, one pointing up, and one pointing down. I also welded triangles of 1/4 inch steel at the intersections of the receiver tubes. I put a lot of welds around this as the stresses can be pretty high.
/ Owner built PT attachments? #10
Thanks, but I was asking about the boom pole itself. ;)
/ Owner built PT attachments? #11
/ Owner built PT attachments? #12
Some more.
/ Owner built PT attachments? #13
Oh! It's just a 2 3/4 inch pipe, 1/4 inch wall thickness with a 2 inch receiver tube at each end (one male and one female). I welded chain links or something every so often to give it intermediate connection that I can hook a chain hook to. This way you can lift heavier items if being close is OK. The female 2 inch receiver allow me to plug other things into it. See attached pictures.
I also made a shorter boom pole about 4 feet long. I use this most. I can also put them in series, but it is very hard to control at this distance.
I have also made a minifork lift that I use for stiring up a burn pile. This way I don't have to get too close to the burn pile.
/ Owner built PT attachments? #14
Thanks, Bob. It was the plug-in pole itself that intrigued me. I already have an adapter plate with a receiver. The receiver is welded to the plate longitudinally, instead of butt on, so it should be strong enough without any gusseting.
/ Owner built PT attachments? #15
Here is a pic of fence stretcher I built for a job I am now in the process of doing. It works pretty well. You are able to tilt or lift the fence as to stretch and place it just right.
/ Owner built PT attachments? #16
/ Owner built PT attachments? #17
Here is another 2 inch receiver with my light duty homemade quick attach plate. I also added this quick attach plate to my gas welder tank rack. So I now have a welder as an attachment.
/ Owner built PT attachments? #18
Grapple made from a towing hitch and some ripper shanks.
A backhoe grapple
A tree snipper.
/ Owner built PT attachments? #20
Your welcome Gravy :)
I think the boys may want a fresh thread about PT attachments since I'm not a member of the PT club anymore, nothing wrong with that.
Just keep in mind I may be back as a 422 owner one day in the near future. I really like my Kubota BX but, on the other hand I do miss my PT adventures.
I have this recurring dream that one day soon Power Trac may switch over to the Kohler engine. Or is it just a dream ;)
If not... I'll have to take another chance on Robin and the break away steering piston curse... :rolleyes: Everyone have a great Turkey Day.
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
Yamaha Golf Cart (A64047)
Yamaha Golf Cart...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2020 ASV RT65 (A60462)
