overrunning clutch
/ overrunning clutch #1
EJG42
eatonville ,washington
nothing yet
I probibly missed this somewhere but does an overrunning clutch on the pto and a two stage clutch ,two ways to control over rpms with implements?
/ overrunning clutch #2
No......
On a 2 stage clutch, one stage is for the tractor driveline, the second is for the PTO.
An ORC will prevent a large inertia-storing blade, such as a brush hog, from pushing the tractor after the clutch has been disengaged. Some newer tractors have them built into the PTO.
/ overrunning clutch #5
Overrunning clutches are nice but rarely necessary for someone who is familiar with the tractor. On rental units or if you have people working for you who only occasionaly operate the tractor, the clutch prevents the implement inertia from pushing the tractor along unexpectedly. But other ways to deal with it are to slip the pto lever into neutral, or simply avoid driving up to an obstacle with the implement turning at full speed. At the worst, even a 6' or larger rotary cutter only pushes the tractor along a few feet. Once you are accustomed to how the system acts you may not care about getting an overrunning clutch. There are about a zillion tractors without them.
As akways, prompt cheerful refund if info is bogus. Dick B
25 Traffic Cones (A65583)
25 Traffic Cones...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2019 INTERNATIONAL HV613 6x4 T/A SERVICE TRUCK (A59914)
2019 INTERNATIONAL...
