Overriding Clutch Quesitons on JD 1050
   / Overriding Clutch Quesitons on JD 1050 #1
jsiler
I have a Service manual on my JD 1050 that I just acquired and in it it shows that the 850 and 950 has an internal Overriding clutch pack but nowhere does it show that the 1050 has one???? Can some of you tell me if mine has one internal to the tranny or do I need to be installing one on my external PTO output shaft like I have on my TO-30?? If it matters my serial number is #0039XX. If you know the answer for sure, please let me know. I don't want to break something I can't/don't want to spend money on like a new PTO/Tranny rebuild.
Thx: Greasy Fingers
   / Overriding Clutch Quesitons on JD 1050 #2
None of the 1050's needed an external over-running clutch. They have two stage clutch instead. The earlier serial number 850 and 950's had single stage clutches with internal over-running clutch. The later ones used the same setup as the 1050.
Thanks for the clarification.
Greasy Fingers aka -Jim
LONG 2360 TRACTOR (A54756)
LONG 2360 TRACTOR...
2011 Ford F450 Diesel with Just 156638 Miles (A55218)
2011 Ford F450...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A55788)
2017 Freightliner...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2020 SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A52705)
2020 SELLICK...
