Overheating Kubota MX5100DT
   / Overheating Kubota MX5100DT #1
jenaro45
Huntsville, TX
2006 Kubota 2800
All of the sudden my 5100 is overheating every time I mow with my 6 House rotary mower
   / Overheating Kubota MX5100DT #2
How often do you blow the radiator?
Don't use water as it will create mud with all the dust and trash and it will block the fins of the radiator. Blow it with compressed air or a blower.
I just did... found out while doing it that fan/alternator belt is a little loose...will adjust and retry.....that may be the problem...I値l let you know how it goes...
Thanks,
   / Overheating Kubota MX5100DT #4
Yeah it might be. Usually the fan is attached to the water pump also, so if one runs slower, it will affect the engine temp.
Exactly what I figured... haven稚 been able to adjust it yet...it痴 over 100ー down here...waiting for sun to set and cooler environment...😹😹
   / Overheating Kubota MX5100DT #6
Blow mine out with compressed air then wash it out with the pressure washer with a wide fan nozzle. I do that every day when I'm running hay like I am now. get home, blow the machine off (whatever it is), look it over for issues, the blow out the rad and wash it out with the pressure washer.
Just washing it wit water will cause the chaff to swell and block the fins but air then water does the job for me on both my tractors. I can look right through the rad (where I can see through) and it's clean as a whistle. My tractors never overheat.
Just finished 2 hrs of mowing and after adjusting the fan/alt belt temperature never got over the 1/2 way mark...obviously that was the whole problem!
   / Overheating Kubota MX5100DT #9
Nice! Glad you have it figured out and it was actually a simple fix.
And thanks for updating us with results. We usually don't get the final updates on various problems all over TBN.
   / Overheating Kubota MX5100DT #10
Good time to replace the belt, either streached or worn.
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
STORAGE FEES (A52576)
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
