Overheating ? (FE35)
   / Overheating ? (FE35) #1
scottnumurkah
mf35
Hi guys,
Im an idiot.
I was slashing my paddock. Just as i finished the 2 and a half hour job, i noticed smoke coming from the engine (4 cyl petrol). I quickly drove the tractor back in the shed, and noticed that there was some oil coming from one of engine seals (gasket), which probably explains the smoke. She was bloudy hot. I took the front grill off and as i was mowing down old dead oats, oats completely covered my grill in front of the radiator. I am guessing that she overheated as no air was getting through to the fan to cool the engine.
I started it up after it cooled down (and after cleaning the grill completely) and it appears to be running fine after letting it run for around 10 mins, no more sign of oil leaking.
What should i do guys.
Any help would be appreciated.
Cheers
Scott
   / Overheating ? (FE35) #2
G'day Scott thank your lucky stars and keep a close eye on the coolant and the oil and keep going, they are a tough old engine with no alloy head to warp from overheating so you might just have been lucky. And BTW it might be time to invest in a temp gauge for the old girl.
Jon
   / Overheating ? (FE35) #3
Since you probably came close to cooking your engine oil, suggest you change it and the filter...you'll probably be ok...BobG in VA
All appears to be well.
There was bugger all water in the radiator as expected. I filled
her right up, put some fly wire screen over the front grill and
slashed a paddock for half an hour. No more sign of leakage or
smoke. The fly wire screen did wonders for keeping anything
from getting into the radiator.
Fingers crossed shes ok.
Thanks for your help.
Couple of quick questions.
I have an oil pressure guage on the 35, but it has stopped working. Was fine a couple of months ago. Any ideas why it it would stop working or anything i can check?.
Another quick question. It looks like my 35 has only ever had water in it and not coolant. Would it be wise to flush out the radiator and put in normal car coolant?. Excuse my lack of knowledge with these old tractors.
Cheers
Scott
   / Overheating ? (FE35) #6
Definitely change the oil and filter. When an engine over heats like that it really breaks down the oil. This is important to do.
Hope all goes a well.
Ok i will change the oil and filter.
I am assuming that the sump nut is located directly below the motor, large nut right underneath?. Just drain that out completely and fill her back up with 15w40 grade oil?.
Cheers
Scott
   / Overheating ? (FE35) #8
Cheers
Scott
Yes, sounds like you have the correct drain plug identity. Not sure what climate that you are in but if it is north and colder you manual likely suggests 10w30 for winter. Change the filter also as you need to get rid of all the old oil.
Is the oil filter on the right side (sitting on tractor). towards the front. There is a large canister. I take it i need to undo that and it should expose the filter?.
This is a 57 4 cyl fe35 gas engine
Also should i drain the water from the radiator and put in normal car coolant?.
It only has water in it at the moment.
I am in Australia btw, warm climate
   / Overheating ? (FE35) #10
The filter should say Oil on it somewhere so you need to check. I am not familiar with your machine to tell you for sure. There is a hydraulic filter so don't get them mixed up.
As for the anti freeze, you need auto coolant in the radiator. Obviously you won't be dealing with freezing weather rather the coolant is needed to protect the inners I'd the engine to protect from rust as well as protect from overheating.
Make sure you know why it over heated and that the problem is corrected. Watch it closely next time it's ran to make sure the problem is resolved.
My daughter had an Auzzie stay with us for 3 weeks last year as an exchange student. We all had a great time.
Wish you well.
3-point Boom Sprayer 72ft (A52128)
3-point Boom...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR HYD HEDGE TRIMMER (A51244)
UNUSED FUTURE MINI...
RAINBOW 040 00-402 TI-12 50 HARD HOSE TRAVELER (A51243)
RAINBOW 040 00-402...
2006 BOMAG BW5AS DOUBLE DRUM COMPACTOR (A51242)
2006 BOMAG BW5AS...
