Overheating 2205
/ Overheating 2205 #1
aperry2
I just bought a Iseki 2205 26hp 2wd tractor, I was using it and the light on the dash did not come on but the tractor was steaming when I shut it off and parked it. It has some antifreeze coming from the weep hole in the bottom of the water pump. Any ideas? Also is there a cross reference # for the oil filter on these tractors? Like a NAPA, fram, etc. If not where can I get a oil and air filter for this unit?
/ Overheating 2205 #2
Sounds like the water pump is leaking and needs replaced.
As far as the filters go, do you have the factory part numbers? I can probably cross reference them if you have the factory numbers.
/ Overheating 2205
I am going to pull the water pump off and have it rebuilt. I got some pricing for a new one and it was $270 I called NAPA and they said they could rebuild it for $60. As far as the filter goes it is a Japenese filter with only Japenese writing from what I can see I just bought the tractor and someone has painted the motor and along with the motor they painted the oil filter. I am going to pull the filter off and try to clean it up to get a # off it. I will reply as soon as I find more info.
/ Overheating 2205 #4
I'd sure like to know how this works out. I've got a ts1910 that will need a waterpump shortly. I've got pricing in excess of 450.00$ bucks for a replacement pump. All I need is a bearing and seal.
Please let me know what you've come up with.
Thanks
RB
213078 (A64276)
213078 (A64276)
CASE INTERNATIONAL 3900 - 32' DISC HARROW (A64276)
CASE INTERNATIONAL...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
