Overheating 2205
/ Overheating 2205 #1
aperry2
I just bought a Iseki 2205 26hp 2wd tractor, I was using it and the light on the dash did not come on but the tractor was steaming when I shut it off and parked it. It has some antifreeze coming from the weep hole in the bottom of the water pump. Any ideas? Also is there a cross reference # for the oil filter on these tractors? Like a NAPA, fram, etc. If not where can I get a oil and air filter for this unit?
/ Overheating 2205 #2
Sounds like the water pump is leaking and needs replaced.
As far as the filters go, do you have the factory part numbers? I can probably cross reference them if you have the factory numbers.
/ Overheating 2205
I am going to pull the water pump off and have it rebuilt. I got some pricing for a new one and it was $270 I called NAPA and they said they could rebuild it for $60. As far as the filter goes it is a Japenese filter with only Japenese writing from what I can see I just bought the tractor and someone has painted the motor and along with the motor they painted the oil filter. I am going to pull the filter off and try to clean it up to get a # off it. I will reply as soon as I find more info.
/ Overheating 2205 #4
I'd sure like to know how this works out. I've got a ts1910 that will need a waterpump shortly. I've got pricing in excess of 450.00$ bucks for a replacement pump. All I need is a bearing and seal.
Please let me know what you've come up with.
Thanks
RB
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
(APPROX. 20) WOOD VEGETABLE BINS (A64276)
(APPROX. 20) WOOD...
213091 (A64276)
213091 (A64276)
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
