Overheating 2205
   / Overheating 2205 #1
aperry2
I just bought a Iseki 2205 26hp 2wd tractor, I was using it and the light on the dash did not come on but the tractor was steaming when I shut it off and parked it. It has some antifreeze coming from the weep hole in the bottom of the water pump. Any ideas? Also is there a cross reference # for the oil filter on these tractors? Like a NAPA, fram, etc. If not where can I get a oil and air filter for this unit?
   / Overheating 2205 #2
Sounds like the water pump is leaking and needs replaced.
As far as the filters go, do you have the factory part numbers? I can probably cross reference them if you have the factory numbers.
   / Overheating 2205
I am going to pull the water pump off and have it rebuilt. I got some pricing for a new one and it was $270 I called NAPA and they said they could rebuild it for $60. As far as the filter goes it is a Japenese filter with only Japenese writing from what I can see I just bought the tractor and someone has painted the motor and along with the motor they painted the oil filter. I am going to pull the filter off and try to clean it up to get a # off it. I will reply as soon as I find more info.
   / Overheating 2205 #4
I'd sure like to know how this works out. I've got a ts1910 that will need a waterpump shortly. I've got pricing in excess of 450.00$ bucks for a replacement pump. All I need is a bearing and seal.
Please let me know what you've come up with.
RB
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2015 DODGE RAM...
